20r made into a 22re help
Old Jan 11, 2014 | 11:38 AM
lilyoder_89's Avatar
I got a 79 model motor an put it in my 89 an made it a re an it run fine for a while now you can be driving an it will start loseing power an kinda spitting an sputter an you can floor it an it will take jus a second it will clear up an take off an then it will do it again. An it will run fine for a while an then it will do it again. It gets old . Today I got in it an got to the end of my road an took off an its missing bad . Any ideas plz help
Will a 86 yota computer work in my 89
Old Jan 11, 2014 | 11:59 AM
Black_1985_SR5's Avatar
have you tried the basics like a tune up and check to see if everything is plugged in first thing i would check is the fuel filters
Old Jan 11, 2014 | 02:55 PM
Yes all new plugs wires cab button fuel filter an head gasket an timing chain
Old Jan 11, 2014 | 03:12 PM
93 Toyota 4x4's Avatar
did you send this from your phone...at least i hope so cause the grammar sucks!!!!
Old Jan 11, 2014 | 03:36 PM
Toyota~Boy's Avatar
How did you make a 79 model engine into a RE?
Old Jan 11, 2014 | 07:32 PM
I got the motor out of a 86 22r 2 wheel drive an I put a head gasket an timing chain an the 86 model head gasket was nothin like the one I took off of the motor an the parts store went plum back to a 79 before it looked like my gasket
Old Jan 12, 2014 | 07:30 AM
Toyota~Boy's Avatar
parts store is full of s***.
More then likely you are using a laser block engine from 85-95. Not 84 back.
Old Jan 12, 2014 | 11:54 AM
Idk what year it is but I jus need some ideas what is making it run like it does
Old Jan 13, 2014 | 08:51 AM
muddpigg's Avatar
There's a write on marlin's forum. Knock sensor or lack of a boss for it was the problem.
Old Jan 13, 2014 | 03:16 PM
My block don't a a place for the knock sensor what can i do
Old Jan 13, 2014 | 05:02 PM
I did the check engine lite an it flashed 5 - 2
80Truck
Oct 12, 2025 07:25 PM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
calderp
Jul 27, 2015 09:58 AM
Dakotaneu
Jul 27, 2015 12:03 AM
