What is best Head Gasket for 22re?
Old Jan 6, 2014 | 12:41 PM
flatbed's Avatar
Replaced Head Gasket and it blew after 3,000 miles. Part was from ENGNBLDR and I think a FELPRO. My block coolant holes could be bored out from corrosion, I've read that this can be cause gasket to blow. Does anyone make a higher quality gasket? All copper? Oem?
Old Jan 6, 2014 | 01:52 PM
93 Toyota 4x4's Avatar
Get the OEM and don't worry about it. or do you want one where it is said it's as good as OEM and wonder???
Old Jan 6, 2014 | 01:56 PM
wyoming9's Avatar
Red face
Just what did you torque your head bolts to??
Myself I like to wonder it add excitement to life.
Old Jan 6, 2014 | 02:19 PM
flatbed's Avatar
60lb-ft with new bolts, however I didn't re-tapp the block holes. Might not have gotten all torque to transfer. Stupid mistake.
Old Jan 6, 2014 | 03:11 PM
HighLux's Avatar
oem headgasket with a new set of bolts from engnbldr torqued to 62 ftlb.
Old Jan 20, 2014 | 10:29 PM
My94yota's Avatar
I really doubt its from a faulty gasket, Millions of people use FelPro, anything can be defective but theyre not exactly a low quality gasket or anything....I would be looking more into another issue....WHAT made the first HG to blow in the first place? Coolant leak and made it overheat and blow? Did you make sure the head wasnt warped when you had the head off (assuming it overheated)? Which can cause any head gasket to blow easily since it doesnt have constant pressure on all spots. Has it overheated since it had the new HG put in? or any other related issues?
Old Jan 21, 2014 | 08:27 AM
osv's Avatar
osv
don't use a tap on head bolt holes, just cut a groove in an old head bolt, to clean out the junk.
Old Jan 31, 2014 | 06:41 AM
flatbed's Avatar
Original Head Gasket wasn't blown, replaced it when I did timing chain and cover. Also had head decked and rebuilt. Truck only overheated once 3k later, and that was due to coolant loss into combustion chambers. Did test and it was leaking at #1 cylinder.
the1998sr5
15
Jul 14, 2020 08:35 PM
Colington
Mar 8, 2020 09:51 AM
Sep 4, 2015 09:27 AM
Fundy Rider
Jul 16, 2015 01:35 AM
Coreyr384
Jul 10, 2015 11:13 AM
