PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 [134] 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237
  1. 94 4runner rwd transmission
  2. striped bolt hole on head help
  3. I painted it.
  4. 86 starting problem
  5. 85 2wd IFS help?
  6. Bumpers
  7. stock 91 thinking of what i should do?
  8. rear tailgate regulator spring
  9. Bushings
  10. knuckle bearings
  11. Tie rod end grease fittings wth?
  12. 1st gen mud flaps question
  13. "post your trucks" Toyota Baja Build NEED ADVISE!!!!!
  14. air box opinons??
  15. 4.88s + Aussie Progress
  16. diff swap ?
  17. Crank Pulley Troubles
  18. 3vze loud ticking after running for 30 seconds
  19. Which shocks do I need?
  20. sensor
  21. Battery trays
  22. Overheating now with same radiator
  23. Bleeder-Dude's Official 22re Engine Rebuild Thread - TONS OF PICTURES!!!
  24. Forward shift t case on R151F?
  25. bought an 89 22RE to rebuild and replace my 86 re. Will it work?
  26. tranny swap
  27. Disapointed...31 10.5 15 yokahama MTs and OME 901s on the back
  28. Crazy Starter Battery Idea
  29. Questions about block heater replacement (with pics)
  30. Does the coils of a land cruiser fits a 4runner?
  31. Another yota gone...:(
  32. A little parking lot fun with snow
  33. Rocker Pods
  34. 4Runner Lift gate issues
  35. Transfer case Shifting
  36. Parting out 94 sr5 4runner
  37. what is the diff between ujoints
  38. brakes
  39. One-Piece Tundra Conversion
  40. Fuel problems? Rough
  41. My first time replacing injectors 88 4runner
  42. 95 4runner Remote
  43. Hazard lights won't work, but turn signals do
  44. Cup Holder
  45. oil/fuel/temp gauge help
  46. oil/fuel/temp gauge question
  47. which exhaust should i do
  48. motor swaps??
  49. Thanks! With your help, I have replaced wheel bearings, etc
  50. Anyone recommend 33x12.5 tires on the stock 15x7 wheels?
  51. Head Gasket
  52. Vacuum (Lack Of) Help 3.0
  53. Removing Brake pins
  54. 95 4Runner Sag [Help!]
  55. creeper joint shackle mounts?
  56. Digital Thermometer Install
  57. upgraded throttle body...
  58. Need W56 trans. and TC buying help/advice
  59. Easy question, what are these buttons?
  60. Rod Bearing Math
  61. License Plate Light Braket...
  62. Truck wont even push-start
  63. 3.0 engine codes HELP!!!!
  64. I think I need Glasses
  65. fixed hubs WHY?
  66. anybody had any luck running lead substitute
  67. 4.2 Diesel swap???
  68. Manual truck radiator in a auto 4runner?
  69. Odo Died... Speedo erratic
  70. Need help on flushing my cooling system.
  71. Anybody ever break a diff breather when removing?
  72. HELP!!! '86 XtraCab vacum line
  73. EFI relay COR relay? Last post before the shop
  74. Idler arm bushings
  75. Looking for 3rd gen EXTENDED CAB truck mods - PICS OF 3rd gen EX CABS PLS.
  76. bucket seats in a1988 reg cab
  77. 1988 3.0 fuel problems
  78. Will 88 4runner V6 Starter Work on 88 4runner 22-RE?
  79. front axle help
  80. engine not settling down (major loping).
  81. What Brand is good for Ball Joints
  82. will stock 4runner running boards fit on a pickup
  83. Long Travel Suspension
  84. Lack of power 3vz
  85. Broken Plastic Injector Cap On 3VZE
  86. Tach Troubles
  87. 1989 4runner AC dryer
  88. VAF help
  89. Anyone tried using hydrogen generators?
  90. exhaust problems..
  91. Are there bigger gas tanks?
  92. 87 4Runner rear axle bearings
  93. Knock Sensor
  94. Fuel Pump..no Fuel Filter..no Fuses..no
  95. 98 Fenders 92 truck
  96. 1991 3.0 engine noise
  97. 93' 22re guidance needed
  98. engine violently dies under hard braking?
  99. Calgary Pick 'N' Pull
  100. Clutch/Transmission Problems?
  101. Air Conditioning Help
  102. 87 with strange manual Tranny Problem
  103. anyone need a sfa close to vt craigslist find
  104. Heat in an '88 SR5...very slow to warm up
  105. Ball joint spacers and leaf spring question
  106. New in the yoda scene
  107. My wife is AWESOME.... Look what she bought me!!!!
  108. 91 3vze motor into 95 4runner, what do I have to change?
  109. it pulls hard to the left
  110. My Mechanic Screwed me on my 22RE-C Rebuilt Motor. HELP?
  111. 22re towing
  112. codes 25,31,32,24
  113. cold air intake
  114. 3rd, 4th, 5th in 4Lo?
  115. What's a good SWITCHED power source?
  116. aftermarket cam??
  117. Will these wheels work on a 93 4x4??
  118. Transmission what will fit???
  119. Rod knock?
  120. Throttle Body On Vehicle Inspection "question(s)"
  121. Got some work done this week :)
  122. Pls Advise: Re-Wire Cigarette Lighter?
  123. Soft Top / Tonneau Idea for 1st Gen 4Runner
  124. post-teardown long-haul trip... it made it! me so happy!
  125. Shackle help
  126. New clutch, now slips out of 4th gear??
  127. Wheelin Pics!! 56k Be warned!
  128. V6 or 22r
  129. 22re timing chain mystery noise?
  130. Diagnostic Trouble. Odd codes?
  131. Replacement axleshaft
  132. 3.0 extended crank
  133. I need good news- Headgasket?
  134. 1st gen 4runner roof rack weight
  135. 93 fourrunner engine help
  136. '92 Pickup pulling left when braking
  137. Warn Trans4mer for Tacoma - Will it fit
  138. Poser Pics and some questions...
  139. Engine stumbles and misfires. Why is it doing this?!
  140. 22RE problem
  141. Sold my 88 3.0, picked up a 22re
  142. starting woes
  143. Emisions Help
  144. New Toyota Owner Wants Suggestions, Gears? True Trac?
  145. Buying a used locker: good or bad idea?
  146. some questions about inclines and manual trans.
  147. Need help with Vacuum hoses on 22re
  148. Guide to remove 4runner 1993 front bumper?
  149. Code 11
  150. rattle can flat black paintjob
  151. Having a stuttering/hesitation problem, can't seem to solve..
  152. looking for a 93 v6 front bumper (4runner)
  153. My new rear bumper *pics*
  154. Thermagasket test results
  155. My new 89 runner
  156. CV joint bolt question?
  157. rear differential is leaking from the front seal - pinion seal
  158. Knock sensor
  159. Truck only starts sometimes
  160. knock sensor...
  161. brake and charge light are on
  162. 22re RPM drop
  163. HELP ! Check engine light!
  164. whirring sound
  165. Quik survey: rear springs on your 86-89 4runner ONLY
  166. 7'' trail gear springs
  167. 87 pickup rear tire carrier
  168. 1st Gen 4runner Full Top :D
  169. Rear window switch in console not working properly
  170. Engine is stalling please help
  171. 22R Front Seal replacement
  172. 3vze increase fuel economy?
  173. Rough idle
  174. Aftermarket steering wheel
  175. Clutch noise
  176. shock questions
  177. 22re coolant in exhaust help
  178. Belts squeak under load
  179. Custom cab? Extended cab? What the hell was it? I want one...
  180. Can I swap a 4wd engine and tranny with a 2wd tranny and engine
  181. Where is the 3VZE EGR Blockoff thread?
  182. 94 4Runner Auto Rebuild or Swap 3VZE
  183. no power to the ignition
  184. 3.0 rebuild complete
  185. shameless pics of my topless baby and her new tattoo.
  186. Need help with idle problem
  187. should i paint my tail lights?
  188. 87-88 4runner as a daily driver?
  189. cargo lighting 89 4runner upgrades?
  190. I know Grill Post
  191. 4runner 3.0 running rough, please help!!!!!!!
  192. Rear window relay temp fix
  193. What is this part on the intake?
  194. The 4Runner owns Samurais
  195. Why does my truck not have these features?
  196. Fuel Pump
  197. 22r Head gasket leak
  198. All Pro or Rocky Road
  199. That one oil pump bolt.....
  200. 22re Engine Pinging Discussion
  201. Speedometer drops and loses power???
  202. Power Steering box issue
  203. Electrical Problem. Need help.
  204. 93 with bigger plug wires (8.5's)
  205. Rusty Muff
  206. hey!
  207. Shifter seat, etc.
  208. Quick 5speed swap question about speedo
  209. Rear diff rebuild
  210. Vaccum leak spewing oil? Help!
  211. low and spratic oil pressure???
  212. identify this part please, tracking oil leak
  213. toyota camry v6???
  214. Cast crank for 22re?
  215. Wreck - front corner / bumper damage
  216. One Spark and then......Nothing
  217. 1st gen gas leak / fuel pump bracket
  218. Egads! Motor may be out? engine started running hot
  219. steering gear box interchangable????????
  220. 1986 22R Fuel Pump Problem
  221. squeeling sound from engine pls help!
  222. missing a part for my lift.....do i NEED it?
  223. can't seem to find ADD to manual conversion kit anywhere....
  224. Valve Clearance Question 3.0
  225. New Clutch Need or What
  226. air in cooling system = sudden coolant loss?
  227. Homebrew light bar?
  228. Finally buying my 4runner
  229. 92 4runner sr5 v6 3.0 2wd to 4wd conversion possible?
  230. Anybody parting out a 3VZ
  231. having one hell of a time removing L control arm.
  232. 3.0 head bolts or ARP studs?
  233. Please help won't start
  234. Disable rear ABS light?
  235. Will front revolver shackles work?
  236. Nissan Manual hubs
  237. Timing chain kit???
  238. broken 22re timing chain guides
  239. 30 mph collision pics! You all wanted to see them.
  240. 3.0 cam advance?
  241. Deavers or 4-link rear
  242. Speedo Cable Squeal
  243. Gear driven case shifter not moving are tcase removed
  244. 91 V6 Toyota Pickup Clutch Problem
  245. Auto to man trans swap help (1st gen)
  246. 1990 4runner OverDrive Not there
  247. Need input, coolant leak...
  248. Alternator or battery? (or something else?)
  249. flowmaster help?
  250. I need A/C
