- Recomendations on LC80 lift tall tall VS short short pairs
- 22re trouble shooting
- connecting gearbox to universal joint on steering shaft
- Flywheel
- Hafta sell my beater - central ohio
- opinions on leaf springs
- mounting a 1st gen grill on a 3rd gen truck - anyone done it?
- electrical problems
- Wont turn over?
- 83 grill on 87 pickup
- Leaves Or 4-link?
- For sure???
- Body Swap from an 88 4Runner to a 87 Frame
- Rear brake shoe replacement.
- SWEET rare 2nd gen headlight covers on ebay w/ 5hrs left!!!!!!!!!!!!!!!!
- longer rear shock idea, borrowed from Land Rover
- fuel in the oil?
- How much is my 2nd gen 4runner worth?
- check engine light help no code id
- weird noise from front drivers side wheel
- Towing with stock 91 4runner
- body mount bushings
- Riding Lights (What Gives?)
- 91 4Runner question:
- 1994 4runner auto trans
- rear sag fix with no lift?
- rear shackle
- New toy! Can't wait to install
- rear wheel bearing gone or what??! video.
- Figuring that coolant leak - head or intake?
- Rear Window Problem
- 4wd not working, add bypassed
- new funny noise
- Pizza Cutters...
- need a lil help narrowing the search
- gauge cluster? !? 91 4x4...
- 95 4Runner 4dr-Need R/R qtr wheel opening molding
- Magna Fluxing
- Full off road protection ideas
- Shackle tightness
- Teh one test it didn't pass
- Got rid of that Jake Brake sound!
- 94 4runner running hot on idle
- 88' 22re Engine Problems??????
- Another 3.0 engine noise question
- Pick-up Wiring EWD
- help with 89 sr5
- electronic supercharger
- looking for a second opinion on trany problems
- 1995 starting problem
- fuel injector problems?????
- New Headlight Q's
- Near Overheating
- 3.0 V6 muffler size 2.5 or 2.25?
- 83 pu steering wheel on an 86 pu. direct fit?
- 95 pick up not running right
- Straightening a frame
- mystery anti-freeze leek.
- 89xtra cab rear seat
- Quality Brake Rotors
- 4runner roll bar, should I??
- Diehard Platinum needs minor mod to install
- does anyone actually sell an elocker already modded?
- knock sensor wire part number?
- Opportunity for a GMC donor, What all to take?
- Using 4lo with hubs unlocked
- Werid 4WD issues.....
- BJ Spacer Question
- Rubbing noise (only when cold outside)
- Terrible Gas mileage
- cold valve adjustment?
- 3.0 running too cool
- Shifter vibration
- 2nd gen alternator wiring assistance request
- 5 speed trans noise
- Engine coughs/cuts out very briefly on hwy incline
- New owner, won't start- no check engine light
- Modification laundry list! Any help is good.
- 5uz swap questions
- Cod 71
- well im bored lets see if you are too
- Driveline vibrations
- Another seafoam thread.
- Tire fitment issues!
- Engine choices!!
- check engine light! doh!
- My friend and I need help.
- New drums, now pulsates.
- 3.0 head gasket blown again
- 1990 4x4
- transfer question case again
- Need help centering steering wheel
- I'm doing a valve cover gasket replace ment.
- radiator reservoir is bubbling air
- 4runner parts
- Right hand drive conversion, anybody done one?
- 89 yota wanders bad in 4WD!
- Crushed Reed Valve, need a replacement
- a question to all running 33 x 12.5
- Windshield and trim ?s
- Gearing Advise Pleeaassee!!
- lower control arm
- First 10 emails get free decal.
- IFS CORE, IFS CLUB & SAS CLUB Decals.
- Brakes: Where can I get disc/drums/pads/shoes?
- Online parts catalog? For part#s, etc Newbie
- Preparing for mud racing... Suggestions?
- 3.0L 3VZE rebuild. Need help finding parts
- Which IFS Club decal do you like?
- 2wd flex pics...not what youd think
- Need Help Now!!!!!
- IFS / SAS Club decals
- 3vze air intake hose parts
- PS pulley help
- Difference Aussie vs Lock Right?
- Which Wheels?
- Changed front diff oil...now grinding sound
- replace dash and fuel light.
- 3vzfe acting odd
- 95 runner AT problem.
- questions on 3.0 headgasket
- need help
- 87 pickup on 84 frame
- 4runner clutch/transmission noise
- New brake lines, now soft brake pedal
- IFS differences??
- performancecenter.com?
- My Toyota is SO freakin' TOUGH......
- singed fan wires???
- large flares???
- Looking For Some Local Help For My 4Runner - Eastern PA
- Just Seafoamed...
- Rear End Grinding & clanking
- New Shocks And Fogs
- Supra AFM in 22re
- Instruction on valve adjustment 22re
- Front Mud Flaps part number needed
- Fuel Pump
- Pitman Arm Removal
- Help needed in the UK on a 3.0 Diesel 4wd problem
- Auxiliary Backup Lights
- MSD-6A Install on the 3VZE:: A How-to for the at home mechanic
- stock rims
- Coolant leak...Oring or just RTV *pic*
- 3.0 auto to 5 speed conversion
- Hit brakes, turns come on
- 4runner
- SR5 Gauge Swap problem Fuel guage reading FULL
- 89 4runner E test FAILED
- Wow!!! Lucas Oil an Sea Foam Wow!!!
- mysterious wire / cable / sensor ?? behind dash
- Door buzzer stuck
- 1990 Auto 3vze RPM Fluctuations at idle and others
- 4x4 problems
- Console Help!!!
- sas or buy one that has a solid axle?
- changing transfer case oil..
- Magnaflow Part #
- 4Runner stuck at work with issues
- '92 ADD vacuum line routing...
- IFS diff drop
- Factory wheel off-set
- Stuck Spark PLug
- motor swap, wont start
- Selling the ol' Land Cruiser
- water pump gasket
- Is Anybody Running
- 1995 4runner a.d.d. transfer case
- paint stripper..?
- Motor Help with 1994 4runner
- Alternator or Battery?
- locking tailgate handle
- 3.0 in Camry, same as in 4Runner?
- the 1988 P/U im looking at
- Yes...Its another lift question
- Need fuel injector help !!
- squeal at start up
- Help me with this weber
- 4runner was parcked for 4 years!!!
- Catalytic Converter Theft - BEWARE!
- Fabtech
- Help with E-brake indicator light
- ---ignition. key--- button lock bypass ---(how to)
- 33s or 35s.
- Please help diagnose... engine going DOWNHILL!!
- clutch adj please help!!!!!!!
- egr removal
- Can't remove CV axle
- Head Unit in a truck...
- new header/exhaust = crappy MPG or other cause?
- 4th gear (o/d) weakest link?
- V6 Timing Question...
- K&N FIPK for the 3.0L, pro's & con's wanted
- Need Help
- Knock Sensor
- Bodywork
- Got My Shackles!!!!!!!!!!!!
- Dies when put in reverse
- Hi Lift Mounting
- brake problem, need help
- Will 31's fit on stock 89 Pickup?
- Fuel line issues
- New Coolant Leak Problem - Can I replace this??
- taking out 22re and putting a new one in
- 1990 4x4 2 door t4r?
- Ordering wheels next week... back spacing?
- rear glass question
- does anyone remember????
- 93 pickup clutch problem!!
- Huge engine problem
- what is this part called?
- 1990 V6 Mass air flow flow part #?
- Add-A-Leaf question
- Bench Seat
- Broken Ring Gear?
- Find out about recalls.
- 88 3.0 fuel pump not working
- 1993 3.0 v6 cylinder pressure
- Bad Shackle Angle?
- Auto Trans Shifter is Loose..
- 92 - 3.0 - A little grumpy when shifting...
- 86 carb intake manifold 22r
- i found
- clutch pedal bracket broken AGAIN!! is this a common thing??
- Wind whistle?
- 94 Pickup Rotor Question
- Time for a tune-up
- MPG Reality
- High Output Alternator's for 2nd Gen 4runner's
- power dis box under dash????
- ...and it came back worse?
- Starter Problem
- questions about 3.4 swap - what did it cost you? (and more)
- Need help finding a vacuum line that feeds all 6 cylinders in my '95 4Runner
- 1991 4-Runner...Mind of its own!
- dimmer switch help 2 kinds!
- 1995 knock sensor HELP!!!
- A plethora of things.
- Codes 12 and 14?
- Rod Knock!!! what should i do?
- Biggest Speaker in Doors
- 5Sp Vs Auto
- Old man Emu
- dana 44 high steer Inverted T
- transfer case gears
- Bought an 88
- 87 22re cranks for awhile
- 22re compression levels
- Think I found my coolant leak - please advise.
- Couple of Questions....
