91 4Runner question:
Old Jan 24, 2008 | 07:17 AM
Brown28's Avatar
Hello,
Im looking at a 91 4Runner with a 3.0 3VZE V6 engine (with 100k on it) that had its head gaskets replaced around 6-7k miles ago...how long can I expect the new head gaskets to last since replacement?
Thanks, Brown28
Old Jan 24, 2008 | 07:31 AM
Elvota's Avatar
Professionally done HG replacement using OEM or equivalent parts... could be good for 100,000 miles or more.
DIY done HG replacement done with mystery parts... could be good for 7 miles or more.
The 3.0 has some flaws, but generally speaking if the HG is done correctly you'll have strong reliability for many miles.
elripster's Avatar
There is no way to predict this. There are too many variables affecting engine longevity.
Frank
Old Jan 24, 2008 | 07:51 AM
DCS's Avatar
DCS
DIY with a decent gasket set and reasonable care could last as long as any other.
It's more of a find out who did the job and see if you're comfortable with what you discover.
The best conceivable install by an experienced tech could fail in 1000 miles if there's a blocked coolant passage, warped head, crack somewhere, etc etc.
Drive it, see if it tries to get hot. If not, and everything else seems fine, then it will likely go for a long time.
Old Jan 24, 2008 | 07:56 AM
isaac338's Avatar
they'll last forever if you park the thing and never drive it again.
this question is impossible to answer
Old Jan 24, 2008 | 08:05 AM
Elvota's Avatar
True... DIY isn't necessarily bad or good. DCS has stated it in a much better way than I.
Flying91
45
Apr 11, 2024 04:39 PM
icentropy
Sep 16, 2020 02:47 PM
BeMiceElf
Oct 10, 2015 09:40 PM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
Cplmike
Jul 8, 2015 08:47 PM
