Figuring that coolant leak - head or intake?
Finished my head gasket job last weekend and when I started it I developed a coolant leak into cylinder number 2 after a couple minutes of running.
Started to take it apart again today and drained out about a liter of water from the bottom of the oil pan. So this is a considerable leak for so much water to contaminate the cylinder so quickly.
After removing my intake, I noted that intake port number 2, leading into the contaminated number 2 cylinder had a lot of coolant/water. So this leads me to the following questions:
What is the standard way to test the intake manifold for a crack lying between the coolant port and the number 2 intake port? As you may already know, they are adjacent without much metal separating them. Would I just plug an end and fill with solvent and watch?
How does one come up with a proper hypothesis as to the cause of the water so I can make an informed decision, rather than throwing new gaskets, new intake manifold, new head, in that order until I fix the problem. I'd rather not pull off the head until I'm sure the problem isn't with the intake.
I did clean my block and check for flatness. It all looked good. I chased all my threads. That intake manifold gasket is a flimsy, cheap looking thing. I wonder if it failed somehow.
Don't know. I guess alot of this is stuff only I can answer by doing the work and inspections. I wonder how many "head gasket" jobs are actually faulty intakes?
to be honest, I don't know the make of the gasket. it came in a set. I doubt it was high quality or anything.
I had my head decked but I live in a small town and there isn't a machinist around that is able to do much else. I asked a mechanic what they did and they told me they send all their stuff away. So all I could really do for crack checking on the head was visual. I started to check with solvent as I described above but got frustrated and gave up. I wasn't sure what I was doing.
I cleaned the block with a scraper, then a razor, then I wiped it down with paper towel.
Avenged
Jul 9, 2015 07:55 AM
