fuel in the oil?
Old Jan 24, 2008 | 12:04 PM
weakyota91's Avatar
fuel in the oil?
i got this little 92 pickup with a 22re and its got a new head gasket and i had a engine builder guy check out the head he cleaned it up surfaced and pressure tested it. any ways i also had to change the air flow meter it was no good. I also had my injectors checked out one was bad so i replaced it along with my fuel filter. Any ways its all together now but it only runs on 2 cyliders #2 and 3. i pulled the spark plugs and those ones look good but 1 and 4 look carbon fouled they are gettin spark but i t seems like they're not firing. i dont think its the fuel pump, when i jump with a paper clip i hear it kick on i also disconnected the fuel return line and it pumps fuel it doesnt seem like its 40 psi though but i dont know if its supposed to be since its just the return. also when i check the oil it seems really thin and it almost seems like it mixed with gas dont really know if thats even possible. if you guys could help me out id appreciate it ive done a few other posts but no one ever seems to reply. Also i was wondering if it could possibly be the computer thats messin up ? thanks
Old Jan 24, 2008 | 12:30 PM
MMA_Alex's Avatar
gotta figure out why 1 and 4 aren't firing first. If they're carbon fouled i'd try replacing em, and see what happens. Should also test the plug wires (FSM)
you need spark, compression, and fuel for each cylinder to work. troubleshoot whichever you're missing to start, and work from there.
Old Jan 24, 2008 | 12:39 PM
weakyota91's Avatar
the thing is i took the cap, rotor, sparkplugs, an wires off my other truck that is a 91 22re and it runs good. so i've checked spark and it seems fine. it seems like a could be fuel but i dont understand why 2 and 3 fire and 1 and 4 dont like i said the injectors were al l cleaned and worke d fine yesterday. so im wondering if there is any sensor or the computer itself that could be the problem
Old Jan 24, 2008 | 12:51 PM
MMA_Alex's Avatar
so you're saying spark is good across all 4? Unhook the coil, crank the engine, and then pull the spark plugs and see which ones are wet with fuel.
Old Jan 24, 2008 | 12:57 PM
weakyota91's Avatar
alright i'll give that a try and let you know what happens
Old Jan 24, 2008 | 01:29 PM
weakyota91's Avatar
alright well that didnt work to well i cranked itover for a while and it looked like cylinder 1 got wet and the other three stayed dry which makes no sense cause cylinde 2 and 3 are the ones that look like they work properly. another thing that happens when its running a i can take plug wire 4 and put it on clinder 1 and it doesnt back fire or anything
Old Jan 24, 2008 | 02:36 PM
MMA_Alex's Avatar
ok well then you need to figure out why there isnt fuel in the other 3 cyls... check fuel pressure, check that the injectors are plugged in and working, etc
Old Jan 24, 2008 | 02:40 PM
weakyota91's Avatar
how do you think i should go about checking the fuel pressure i dont think my manual says nyhing about that
Old Jan 24, 2008 | 03:07 PM
MMA_Alex's Avatar
fuel pressure gauge on the fuel rail...
Old Jan 24, 2008 | 03:17 PM
weakyota91's Avatar
sorry, do you think you could explain it a little better. Am i goin to have to take off the upper air chamber. and where do i put the guage? at the end where the fuel return is? thanks
Old Jan 24, 2008 | 04:26 PM
thook's Avatar
Run a compression test. I have an idea, but I want to know what you're results are first.
Old Jan 24, 2008 | 04:28 PM
thook's Avatar
I thought this sounded familiar....
https://www.yotatech.com/forums/f116...oblems-135515/
Why are you starting a new thread about it? Doesn't matter......just curious.
Old Jan 24, 2008 | 07:03 PM
dcg9381's Avatar
Yes, you have to take off the upper plenum.
Drill the end of the fuel rail, towards the front of the truck.
Tap 1/8 NPT.
Insert fuel pressure gauge (small one).
I seriously doubt if this is your issue... Either all the injectors have pressure or none of them do.
Old Jan 24, 2008 | 08:35 PM
80W90's Avatar
exactly. if there is fuel in oil, and the plugs are not cleaning, there is a ring problem. do compression test before anything else.
Old Jan 25, 2008 | 10:03 AM
weakyota91's Avatar
alright ill run a compression test today and let you know what it turns out to be.
Old Jan 25, 2008 | 10:05 AM
weakyota91's Avatar
well idk, the last thread was before i had my injectors cleaned and checked out proffesionally, and now for some reason it also seems like there is fuel in the oil
Old Jan 25, 2008 | 10:06 AM
weakyota91's Avatar
Tap 1/8 NPT.
thanks i dont think its the problemm either because when it runs i can rev it high but only two cylinders fire
Old Jan 25, 2008 | 12:51 PM
dcg9381's Avatar
If you've done the TPS adjustment, set timing, checked the plugs - do you know which 2 are not firing? The injectors are setup with two banks. They're tied together in the harness, but I've heard that this connection can get crappy and break.
Old Jan 25, 2008 | 05:11 PM
weakyota91's Avatar
alright i got some compression #'s for ya #1 180
#2 165
#3 180
#4 175
thanks for your help
Old Jan 25, 2008 | 05:13 PM
weakyota91's Avatar
im not sure i know what tps adjustment is. thats throttle position sensor right?
cylinder 2 and 3 were firing
1 and 4 dont seem to be any more info would help a lot thanks.
