Magna Fluxing
Old Jan 23, 2008 | 07:36 AM
Itoyota's Avatar
Unhappy Magna Fluxing
12345
Old Jan 23, 2008 | 08:13 AM
yotaman90's Avatar
Ever heard of head studs? I'm not sure if they sell them for the 22RE, but I know that they have them for the 3VZ-E. They're supposed to really help if you keep having headgasket failures
Old Jan 23, 2008 | 08:20 AM
MMA_Alex's Avatar
x2 on the head studs. I think...ARP makes a set. They're not torque to yield like the headbolts are (which means they're supposed to be replaced each time you take em out)
yotaman90's Avatar
Here's the site for the 3.0 studs http://www.doaracingengines.com/
Old Jan 23, 2008 | 08:21 AM
yotaman90's Avatar
Exactly!
Old Jan 23, 2008 | 09:28 AM
Georgiadave's Avatar
I don't think 22RE headbolts are torque to yield. I do think it is a good idea to replace head bolts that have been in and out as many times as these seem to have been. Head bolt failure does not seem to be a cause of many 22 RE head gasket failures. Studs are probably overdoing it.
Old Jan 23, 2008 | 09:43 AM
Targetnut's Avatar
well obviously somethings not right.
Is the head gasket actually blown? In other words are you sure the head or block are not cracked or warped?
Bad parts, improper assembly, warped or not properly cleaned gasket surfaces could lead to blown head gaskets.
Make sure that the head bolt holes are cleaned and the bolts cleaned and lubricated before torqueing
The 22R does not have torque to yield bolts.
Make sure you are using a good torque wrench and proper technique.
Old Jan 23, 2008 | 11:31 AM
Jay351's Avatar
Oh god no... I would rather re use TTY studs then ones from DOA...
Old Jan 23, 2008 | 02:57 PM
notanymore's Avatar
there have been more than a few people on this site scammed by doa, there used to be a thread about it. there were some pictures of his head studs in there too, lets just say they weren't very consistent in length.
Old Jan 23, 2008 | 04:48 PM
Itoyota's Avatar
Old Jan 23, 2008 | 04:58 PM
breknraj's Avatar
So -- Where does Magna-Fluxing come into this picture?!!?!??
Old Jan 23, 2008 | 05:51 PM
Itoyota's Avatar
Old Jan 23, 2008 | 07:13 PM
runethechamp's Avatar
I suggest you do OEM with all your parts. Gasket, headbolts, whatever.
Old Jan 23, 2008 | 08:15 PM
isaac338's Avatar
the head's fine.. what about the block?
Old Jan 24, 2008 | 03:49 PM
breknraj's Avatar
I know what magna-fluxing is, since I'm certified to perform it, but the OP titled the thread Magna-Fluxing, and then never indicated that it was, or going to be, done.
Old Jan 25, 2008 | 03:43 AM
Itoyota's Avatar
Old Jan 25, 2008 | 03:45 AM
Itoyota's Avatar
Old Jan 25, 2008 | 04:17 AM
Skidmark's Avatar
I believe the only correct way to check alum. heads is by pressure testing and or dye check..Magna-fluxing is using magnetic power and and eletromagnet to seperate the poles on ferrous metals and see cracks. JMO Been doing it all my life. Bi metal engines do strange things when they heat up.
Old Jan 25, 2008 | 06:17 AM
isaac338's Avatar
dude.. 2, c, and b are not words. don't use them as words, it makes you look like a small child. sorry
however, 2cbs are fun little pills.. look them up!
Old Jan 25, 2008 | 07:46 AM
yotaman90's Avatar
Really?!?!?!? Sorry I didn't know, I'd heard somewhere that DOA was a good company, guess not! That was the only place that I knew that had head studs though.....my bad
