Using 4lo with hubs unlocked
Old Jan 22, 2008 | 12:15 PM
89silverpu's Avatar
Is it ok to use the low gearing of 4lo and still be in 2wd? There are some roads in the hills by where I live and first gear isn't a low enough gear to get up them easily so I put it in 4lo without locking the hubs out so I'm assuming the front driveshaft is spinning but the wheels aren't getting power. Is this bad for the drivetrain in any way?
Old Jan 22, 2008 | 12:16 PM
tc's Avatar
tc
nope, no problem at all. If you have to do it frequently though, I would recommend a twinstick - will give you 2LO whether the hubs are locked or not (and from inside the cab obviously)
Old Jan 22, 2008 | 12:19 PM
4rockclimber's Avatar
From: From San Francisco, but attending school in Pomona CA
i used 4 low with the hubs unlocked to tow a friends busted cj back to the pavement with no issues at all,
89silverpu's Avatar
Thanks! I don't do it alot just when I go up the roads which is only about once a month at most.
Old Jan 22, 2008 | 12:26 PM
jjrgr21's Avatar
i'd regear if it's bad enough to need low range
Red3.slow's Avatar
Unlocked hubs and 4lo is the cheap way to get a 2lo. I've never had problems when i've used it and it's nice to have to get up some steep slick hills.
This has been coved many times, search please
Old Jan 22, 2008 | 12:33 PM
bigt's Avatar
why not use 4wd?? is it not snowy enough to need them or you just dont want to get out and lock the hubs
Old Jan 22, 2008 | 12:57 PM
EWAYota's Avatar
quick hijack, but almost on topic. When you shift into 4lo with the hubs locked, do we just have the 4x4 light illuminte or is there a 4lo light as well? Can't remember and when I put it in 4lo the other day, made me wonder.
just a 22re's Avatar
i use 2lo for burn outs cause that just how it is lol and for some problem and just look out for this when in 2lo you rrear end might go right to a locked rear or its just mine but yet when ever i give it power it clunks and goes to a locked then it stops when theres no power going to the rear well its fun 2lo burnouts baby!!!!
Old Jan 22, 2008 | 12:58 PM
89silverpu's Avatar
Its not snowy at all it doesn't snow where I live and 4WD isn't necessary its a paved road just really steep...and sorry I didn't have time to search I normally do I just didn't have time this time...and regearing is expensive so if this doesn't cause any problems I might as well do it!
its 2wd no light or 4wd w/light
Old Jan 22, 2008 | 01:09 PM
Brendan's Avatar
just don't shift on the fly with the hubs unlocked.
Old Jan 22, 2008 | 01:24 PM
what grade is this hill your talking about any pics? i wanna see this if it takes a yota 2lo just to climb
Old Jan 22, 2008 | 01:42 PM
notanymore's Avatar
no 4lo light, just for if you are in 4wd or not.
Old Jan 22, 2008 | 02:01 PM
82yota's Avatar
It shouldnt hurt anything. My dad and I use this when pulling boats out on paved ramps where we arent concerned about spinning so much as just being nice and easy on the clutch. Also when getting overly heavy loads moving around town I go through 1-3rd gears in low then shift to high and into second. It pretty much lines up perfectly and its like having a few lower gears to get things moving. Much easier for hill starts towing a 21 foot cabin cruiser.
Old Jan 22, 2008 | 04:49 PM
EWAYota's Avatar
Good. I never pay attention to the lights when I'm in 4wd, just remembered seeing a 4lo light at one point, but that was with my F150.
Old Jan 22, 2008 | 05:00 PM
rdlsz24's Avatar
I also use it to pull our jet skis up the launch ramp. It makes it so much easier with the limited power of my 22RE.
Rob
Old Jan 22, 2008 | 05:08 PM
4Crawler's Avatar
I use 2LO all the time. With dual t-cases, I just put the front cane in low range. Handy for backing into tight parking spots, in stop-n-go traffic and for going up steep hills at high elevations, like when you find 1st gear too low and 2nd gear too high. Drop into low range and you split the gearing in the tranny and have many more gear choices.
Old Jan 22, 2008 | 05:13 PM
ovrrdrive's Avatar
I also do it all the time. No worries. I park on the other side of a steep ditch a lot and use it so I don't have to rag my clutch or spin the tires going up the hill. I just drop in to 4lo and crawl up the hill and then shift back and drive off. I get plenty of traction in 2wd, I just need the lower gears sometimes.
Solid advice... With the hubs locked everything is spinning at the right speed so shifting on thew fly is possible. I'd hate to hear it if someone shifted on the fly at 25 miles per hour with nothing moving in the front end.
Old Jan 22, 2008 | 05:21 PM
spanish-road's Avatar
I have had to put it in 4lo and just 4wd wouldn't work, Im talking some steep stuff, it was 40-50% slope, with the seatbelt on I was hanging from it.
