Coolant leak...Oring or just RTV *pic*
Old Jan 18, 2008 | 07:35 PM
Albert.G's Avatar
Hey ladies and gentt....i noticed my truck just started to leak a bit of coolant...ive searched and searched, couldn't find neither the name or if there was an Oring or just RTV....well its leaking from the seal...looks like its already been taken off.
Old Jan 18, 2008 | 07:43 PM
Albert.G's Avatar
id take it off...but if theres an oring...im shrt out of luck.. come on boys...someones gotta know
Old Jan 18, 2008 | 08:11 PM
Albert.G's Avatar
bump to the top
Old Jan 18, 2008 | 08:31 PM
WCorbett's Avatar
Im not sure but wheres your battery?
Old Jan 18, 2008 | 08:36 PM
Albert.G's Avatar
pssh...batterys are for losers...i run the truck off the alt...it runs better that way...plus it saved me 5 lbs... nah im kidding, i just found a random picture of a 3veeeezeeeeeeee off the net..(not mine)
Old Jan 18, 2008 | 09:13 PM
Anubiscougar's Avatar
o-ring? isn't there a gasket, not an o-ring? I can't remember though, i could be wrong. If it's leaking from the hose, rpl the hose & re-finish the fitting. if it's the fitting to the lower fitting, rpl the gasket/o-ring. if you feel cheap & don't wanna spend money, sure rtv it up.. clean the surfaces well though.
....orrr... do a motor swap, the easier fix.
Old Jan 18, 2008 | 09:30 PM
infiltrator's Avatar
i was about to say, dang that engine needs some CLR and a wash
Old Jan 18, 2008 | 10:12 PM
Albert.G's Avatar
the place where the hose meets metal is fine, just the metal touchin metal is leakin a bit...if theres a gasket...then sure id replace it, but gotta wait till monday :thumbdown:
Old Jan 18, 2008 | 10:31 PM
Green93's Avatar
There is no gasket or o-ring in that location. You will obviously have to drain some of the coolant to remove it. Just clean out the groove on the underside of the top piece as well as the other mating surface. Apply RTV, refill the coolant and you're set.
Jason
Old Jan 18, 2008 | 11:01 PM
Albert.G's Avatar
THANK you...thats why your number 1
Old Jan 21, 2008 | 05:37 AM
GSGALLANT's Avatar
Jason
X2. No gasket. A bit of scraping, and a new bead of FIPG and you'll be good to go.
Blamalam
Mar 12, 2022 07:34 AM
the1998sr5
15
Jul 14, 2020 08:35 PM
JaredL
Mar 28, 2016 09:08 PM
94 Newbie
Aug 6, 2015 10:33 AM
itzmywife's
Jul 25, 2015 04:55 PM
