Are there metal stub pipes for the heater hoses on a 3.4 (pic) ?
Old Jul 24, 2015 | 12:38 PM
94 Newbie's Avatar
One of my coworkers pulled in the parking lot with steam coming out his hood, and the CEL on. He said it happened just as he was close to work.
WE looked, and while there was coolant all over the water control valve and heater hoses on the back side of the motor this morning ,it was all gone by an hour or so later.
We attempted to refill the radiator and see where it was leaking from, but never could fill it up enough as once you hit a certain point it would spill out the back of the engine - not sure from where - and you could see it running down the passenger side block (rear) in front of the exhaust.
This a '99 4 Runner 2WD, and I found a pic on the web that shows where the heater hoses go & looks like maybe there are metal stub pipes.
If so, anyone ever had one rot out ?
Just scratching my head as I did not see any obviously blown hoses.
pic here :
Thanks !
Britt
Old Jul 24, 2015 | 12:59 PM
wyoming9's Avatar
Red face
Maybe look back in there with a mirror
Has to be a pretty good hole if coolant just ours out
Old Jul 25, 2015 | 05:07 PM
KZN185W's Avatar
check the rear heater lines. there have been quiet a few cases of the rear heater metal lines getting corroded
Old Aug 6, 2015 | 10:33 AM
94 Newbie's Avatar
Survey says : Intake Manifold
At least, that is what my co-workers mechanics replaced.
The lower portion, between the heads - you can tell it's new & shiny versus the rest of the motor.
They used Toyota red coolant as well.
I would have liked to have seen what the old one looked like, but oh, well.
in case you were wondering !
Britt
the1998sr5
15
Jul 14, 2020 08:35 PM
Sep 4, 2015 09:27 AM
msane99
Jul 17, 2015 10:13 AM
Fundy Rider
Jul 16, 2015 01:35 AM
94whiterunner
Jul 12, 2015 07:15 PM
