Rod Knock!!! what should i do?
Old Jan 14, 2008 | 05:04 PM
brentcole5's Avatar
I went to start my truck for school yesterday and knocked on start up for a second and went away which is unusual for my truck and i didnt think much about. I let it warm up for about twenty minutes or so and came out to go and as soon as i hit about 2500 rpm it knocks more and its definately a bottom end noise i was thinking i would just throw some crank bearings in it and try that oh and its a 1991 v6, any advise would be awesome, Thanks.
Old Jan 14, 2008 | 05:22 PM
bwhyit's Avatar
I think I saw a 5vz on here for 900 w the ECM. I'd explore that option...
Old Jan 14, 2008 | 05:34 PM
brentcole5's Avatar
i have one in my garage with only 38k on it but i have looked well into that swap and i guess im not that bothered with my 3vz, it seems pretty reliable and has enough power for me but who knows yet i might just bite my lip and do the swap, the only problem is i have to do a Lt1 swap in my chevy pickup too so i gotta get my ducks in a row first
Old Jan 14, 2008 | 05:35 PM
GenXr's Avatar
Better get it fixed or you'll be walking!
Many people have said those motors are expensive to rebuild. I can't say b/c I haven't priced one. You could try and find a used one at the junk yard, rebuild yours or swap to a different motor.
G/Luck which ever method you choose.
Old Jan 14, 2008 | 07:17 PM
burnscore1's Avatar
Probably a dumb question, but have you checked the oil? I know when mines low, it knocks for a few seconds. I don't drive it though when it's like that, so don't know if it knocks @ a higher RPM.
Good Luck!!
Old Jan 14, 2008 | 07:22 PM
toytech76's Avatar
At my shop, it usually runs about 5K to do a full rebuild using toyota parts, machine work, valve grind and some misc parts. You'd be better off with the 5VZ
Old Jan 14, 2008 | 08:04 PM
TNRabbit's Avatar
I did my own rebuild and spent less than $3000 including about 2200 in tools which I now own. Plus I installed a cat-back exhaust & put new calipers/bearings on the front wheels. STILL all for about $3000.00
kawazx636
Oct 6, 2021 03:03 PM
ladybugRC
458
Aug 21, 2020 10:41 AM
primordialbeast117
Dec 19, 2015 12:23 PM
83yotastockR
11
Nov 10, 2015 06:54 AM
moparbay
Oct 6, 2015 09:24 AM
