Hi Lift Mounting
Old Jan 16, 2008 | 08:42 AM
isharj's Avatar
Hi Lift Mounting
Where and how are you guys mounting your hi-lifts? I'm wanting to put mine on the roof rack and wanted to see how you guys are doing it.
Old Jan 16, 2008 | 08:59 AM
rdlsz24's Avatar
Check out this thread:
https://www.yotatech.com/forums/f116...ghlift-126681/
Rob
Old Jan 16, 2008 | 10:12 AM
tc's Avatar
tc
What kind of rig?
Keep it inside if you ever want it to work ...
Old Jan 16, 2008 | 10:19 AM
isharj's Avatar
1990 4Runner.
They get that bound up keeping them outside?
Old Jan 16, 2008 | 01:08 PM
tc's Avatar
tc
Yeah, every one that I've ever used that people keep on the outside of their truck has needed A LOT of persuasion to work properly.
Every one that has been kept inside the vehicle has worked much smoother.
Old Jan 16, 2008 | 02:48 PM
Elvota's Avatar
Originally Posted by isharj
1990 4Runner.
Do you have the factory spare rack? If you do, and don't mind it outside...
...then this works:
Keeps it out of the way and easy to access. I live in AZ so the weather is pretty compassionate towards steel left outside. I do find if I shoot it with some WD-40 which I keep handy it works like a charm.
Old Jan 16, 2008 | 03:21 PM
James Dean's Avatar
I made a custom rack that holds it on the pass side. The center stud has a hole thru it so I can lock it and leave it.
Old Jan 17, 2008 | 11:09 AM
isharj's Avatar
Thanx guys!!
Old Jan 17, 2008 | 11:36 AM
mt_goat's Avatar
I like my Loc-Rac, makes it easy to secure and remove it. You just need to find something to bolt it to. Like TC said, inside is better than outside. Mine is over the rear wheel well bolted to a piece of angle iron (from an old bed frame) which is secured at the factory tie down bolt holes.
The thing I hate about putting up on a roof rack is it just makes you that much more top heavy. I'm more worried about a roll-over than most anything else, except maybe fire or theft.
Old Jan 17, 2008 | 09:17 PM
High Water Drifter's Avatar
I put mine inside. I've also heard they love to rust if you keep the outside, but using a bag to store it in like prior post looks good. Steve at sonoran steel offers a rear cargo area hi lift mount. my 2 cents...
Old Jan 18, 2008 | 04:56 AM
mt_goat's Avatar
I don't think I'd recommend the bag to anyone running one outside. It would keep the dirt off pretty good, but they aren't really that water tight and would end up holding water inside and rusting it faster. If you run one outside I'd say clean and lube it up often, and make sure it still works. Maybe use it to rotate your tires every 3000 miles or something to make sure its working ok.
Old Jan 18, 2008 | 07:50 AM
isharj's Avatar
Any pix of this?
Old Jan 18, 2008 | 07:54 AM
4Crawler's Avatar
I just use an old ski binding cover on mine:
It has lived mostly outside for over 20 years now and still works fine, although has been inside for the last couple of years:
http://www.4crawler.com/4x4/ForSale/HiLiftMount.shtml
I give mine a shot of PB Blaster or similar penetrating oil every year or two.
Old Jan 18, 2008 | 07:55 AM
dropzone's Avatar
Fossilized
Just remember when mounted outside (or anywhere) that like anything, a little maintenance goes a long ways...a shot of wd-40 or something will keep it working when you need it...
Old Jan 18, 2008 | 08:58 PM
mt goat- i'm not recommending storing outside, just saying the bag LOOKS GOOD. like i said, i store mine inside.
Old Jan 18, 2008 | 09:00 PM
Any pix of this?
isharj- check out sonoransteel.com and look for jack mounts
Old Jan 19, 2008 | 06:20 AM
mt_goat's Avatar
Gotcha
Old Sep 8, 2010 | 09:38 PM
86bedlesstoy's Avatar
Any pictures of them mounted in any early year pick up beds?
Old Sep 9, 2010 | 05:47 AM
cootees's Avatar
loc-rac mounted to the surco basket.
Old Sep 9, 2010 | 05:55 AM
gary_the_4runner's Avatar
i like the simplicity of 4crawlers mounting system in the rear of the 1st gen runners, nice work!
