89 4runner E test FAILED
Old Jan 18, 2008 | 04:38 PM
eightnine's Avatar
Just failed my trucks last Etest pretty bad and was wondering if anyone has any thoughts on what the problem could be?
Results are:
40KM/H
READING/LIMIT
HC 285/ 85
CO% 4.23 / 0.47
CURB IDLE
READING/LIMIT
HC 280/200
CO% 6.62 / 1
It failed it pretty bad, i know the 02 sensor is probably bad since its original but why the high CO?
Old Jan 18, 2008 | 04:59 PM
bigt's Avatar
how old is your cat?
Old Jan 18, 2008 | 05:09 PM
eightnine's Avatar
brand new cat installed with entire exhaust system minus the manifold last january
Old Jan 18, 2008 | 05:51 PM
bigt's Avatar
and it passed fine 2 years ago?
i always make sure to run the engine so its good and hot before you take it in.. and also a oil change a week before
eightnine's Avatar
im pretty sure it was faked two years ago as it was running worse than it is now
Old Jan 18, 2008 | 05:54 PM
bigt's Avatar
o ok i though you had the truck for a while... i have had a 87 and then a 94 and 93...... i have never had issues doing what i posted above the only time i failed was when i was using a ford ranger cat converter... is your check engine light throwing any codes?
Old Jan 18, 2008 | 05:56 PM
eightnine's Avatar
nope no codes are being thrown.. if the o2 was malfunctioning would there be a code 100%?
Old Jan 18, 2008 | 06:00 PM
bigt's Avatar
no mine blew out before and it was loud as but no cel came on.... wait for someone eles to chime in ...
Old Jan 18, 2008 | 06:02 PM
eightnine's Avatar
yeah im hoping for that, thanks dude
Old Jan 18, 2008 | 07:07 PM
bigt's Avatar
ife you know the person at the drive clean once i used my 4runner to get my buddys 4runner to pass.... ust use your vin number ...also if your really stuck i might have a hook in hamilton
Old Jan 18, 2008 | 07:18 PM
infiltrator's Avatar
try and see if you can find i think its made by mobile, but its called "low emissions gasoline" and it might give you the "edge" lol.
Old Jan 18, 2008 | 11:52 PM
iam_turner's Avatar
Run super thick oil in it - 40 weight before you do your test. This could make a difference, my friend failed and then changed his oil, and a few other things, and then passed.
I dunno....
Move to Alberta.
crashburnoveride
Jul 10, 2015 06:39 AM
horunner1x
Jul 10, 2015 06:33 AM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
timmJ
Jul 7, 2015 02:01 PM
Jnkml
Jul 6, 2015 01:20 PM
