- sun roof
- 95 3vze sluggish problem
- Fixing the rear quarter panel rust - 90 4runner
- Rear Diff squeaking
- 1986 4runner tranmission solenoid replacement writeup
- Safe max RPM for a 22re?
- OME 900 Install
- Rough idle when hot
- Fitting a cherokee tank where the spare would go
- Need lots of help with rebuilt 22re!
- Brake Fluid Capacity
- Post EGR Mod, What don't I need
- ADD Actuator Stuck
- 4wd high winning
- Supra MAF with 93 pickup?
- Need Help with my 91 pickup
- 3.0 missing under load
- New tires on the ole' girl!! Whoo hoo! Pics
- efi fuse keeps popping
- '86 Turbo Toyota Transmission
- Replacing Stock Calipers With V6 Calipers ?.
- Camshaft issues
- LSPV Bleeding
- removing my grill
- Diff fluid opinions and advice anyone?
- Parking brake not engaging.
- 3vze intake manifold cleanup & port and polish job
- 3vze hose question
- stuck valve?????
- In the Middle of 3.0 T-Belt and Heads.. Have Some Questions
- 88 2WD 22R Questions
- Rear leaf spring ride height 2nd gen 4runner
- shake down run in the 4runner!
- mulch hauling
- Hellwig helper springs
- Oil light and condensation
- Need help. After replacing timing chain 4Runner stalls under 1500 rpm.
- AC fan only works on low
- Anyone want/need bushings for a beck arnley idler arm? (2WD Truck)
- Rear axle leaf spring lift done the wrong way
- how to change rotors on 1994 4runner
- few Questions about hid kits and lights
- 4runner wouldnt start after hg job
- Sea-Foam?...
- Where can I buy an alternator stud for a denso?
- Rocks & Steering Don't Mix
- Sound System In The 2nd Gen Runner
- routing muffler over rear axle
- timing belt tensioner questions?
- 2in coil spring kit
- engine problems
- 92 3vze Auto Tranny Slipping Around 35 mph!
- new Doug Thorley header with Flowmaster 40
- Intake question
- 1994 toyota 4x4s
- Replacing front brakes
- big oil leak on a 88 pickup 22re
- I killed my motor
- idle rpm dropped all of a sudden
- Pacesetter header fitment issues.
- question about 2nd gen 4runner 4wd system and front suspension
- 4runner Head gasket blown???
- Is this the wrong headgasket?
- high idle, cant turn down
- 3.0 pickup head question
- replacing PCV valve- shoudl i replace the grommet too?
- 93 22RE will not idle
- So I'm guessing my rear axle oil seals are toast?
- need inspiration for my 86 pickup.....help
- 88 pickup dash lights not working
- What size Hose Clamp???
- 87 runner sat for 3 years - should I replace all the bushings?
- any clue about 22R exhaust pipe??
- oil pump issue
- Oregon smog harder to pass than Cali
- All Pro sliders for Extended Cab?
- Remanufactured heads (3VZE)
- Truck-Bedz Mattress Pics
- Newest addition to my truck
- Rear window won't go down all the way
- Ordered My Clutch
- 1988 bed on a 1987 frame?
- 91 4runner vibration at 2000 rpm
- engine oil flush? good? or damaging?
- Precision Performance Tuning box chip
- towing a '90 with a tow dolly
- How much hack will this take? IFS & 37's
- Advice needed for valve adjustment and tune up stuff.
- A couple of issues with my 91 PU V6 3.0
- Brakes bleeding me dry!!!!!
- Did I just blow a head gasket again?
- broken tvv aka bvsb valve sensor.
- 87 turbo auto trans
- Auto Trans Bands
- Ground wire went up in smoke
- CV shaft bolts
- need soome help on my rebuild
- Kinda rough start sometimes...
- My new to me truck that sometimes wouldn't start... Story time
- 1990 4Runner Dash Gauges & Fuses
- 87 turbo tranny non turbo engine
- Engine piston good to go or done with??? Expert advice or not!
- Slider Gusset kit....or no?
- rough idle when in gear and sitting
- Are the Thorley's that big of a help?
- odd brake problem
- Rear diff Pinion super loosey goosey
- Having a hard time finding exhaust
- 1987 4runner, planning on Long Travel build
- brakes are driving me crazy
- HELP with check engine light.. trouble codes
- Cleaning the block
- Air Intake
- Best way to tell if you have a head gasket leaking ?
- Toyota4x4907's 22re build
- Silla Radiator
- E-Brake Light Shorting Out Dome & Door Lights
- Replacing oil pump/oil pan
- 3.4 price question
- high idle and tap tap tap.....boom?
- 87 22re 5-spd Throw Out Bearing Hunt
- 2JZ update + clutch question
- 87 pickup transfer case failure
- 92 truck, no compression on cylinder 3, and 60 on cylinder 6 burnt valves, or rings?
- 22r high fuel level in sight window
- Fuel pump?
- 4runner electrical issue? Really weird - please help!
- Power steering issues cant resolve
- mushy brakes that will NOT lock, Ive replaced 90% of the entire system, what next??
- Did the ZUK mod to my 4Runner
- Felpro head gasket & head bolts, junk?
- Any issue w/ swapping rear axle/hub/brakes from passgener to driver side?
- Front Diff replacement
- Help with leaking rear diff.
- 1989 toyota 22-re- wondering where to start
- 1990 toyota p/u 3.0 motor
- Timing chain blues
- Just bought a used trailmaster 4 inch lift
- 22re head bolts too long?
- low oil pressure
- Home Grown Air box/Snorkel
- Ground strap under ignition coil
- Are the Toyota speedo gears made out of plastic?
- 3vze blown head gasket?
- Mysterious Gas Leak? '88 4x4
- idle video - pop/sputter
- -90 3.0 4runner overheats after timing belt change
- How To Convert From EFI To Carb?
- 89 4runner no start
- sub box in 89-95 excab pics wanted
- Exterior/Interior Designes
- Any feedback for Putney's custom machine?!?!?
- Seriously need some help...starting Issue 90 4runner v6
- flowmaster 44 on a 22re?
- 4runner VS. Pickup Chevy leaf swap question.
- Anyone use Amsoil XL 10W40?
- Fuel & temp gauge not working!
- 3.0 3VZE General Timing Question
- 87 4runner-need input
- Bend's new Truck!
- Lifted my truck today!
- Brand new fuel pump LOUD NOSIES!
- $33 coil spring installment.....pic
- throwout bearing replacement
- Crap. My 4Runner won't start.
- My new '95! Pics!
- 95 4runner easy IFS question
- 3vze reman updates
- 89 auto tranny woes!! help!!
- Does Knock Sensor Only Listen to #3 Cylinder 22RE
- Losing power
- head gasket, head or block???
- will not start everthing is dead
- bad catalytic converter?
- Slight Lag
- new exhaust: should i complain about this?
- spark piug
- Supra AFM swap questions
- TPS confusion...
- Very strange valve adjustment issue
- 88 4 runner engine swap ????
- Brake issues..91 4x4 Pickup
- Stupid stupid fuel issue: 86 22RE
- sas swapped 94 yota
- Steering Shaft Rag Joint
- 87 Turbo 4Runner Anyone?
- ISR mod
- Front Diff Oil
- My new 87 4runner with problems
- brake rubbing / vibration when braking hard while stopped
- Fluid quantity list.
- '88 4runner problems, too many to list...
- 89 toyota sr5 22re ac works but ....
- LC Coil question
- How can i remove the transfer case breather
- brake lock up when engaging 4wd
- Not the usual coolant disappearing act
- DIY port & polish on a 22r??
- fuel wiring help on my jz swap in my 91
- Junkyard 4.56 E-locker
- No Power under load, Misfiring ect
- Do LC steering wheels fit pickups and 4runners?
- ome rear suspension users: opinions please
- truck have starting problem
- Drop tank or remove bed? What do you think?
- A/C problem/repare/replace?
- 22re starter problem..flex plate backwards??
- 89 4runner head issue
- Can't get rear axle shaft back into 3rd. HELP!
- I need help with EGR
- i think i have a bad ecm...
- check engine light
- throttle sticking
- Major overheating problem! 94 4runner V6 2WD
- 3vze wont start after head job
- Timing question
- Easy lower valance mod+ pic
- CSF radiator cap
- coolant through EGR?
- 4x2 vs. 4x4 idler arm: What's the difference?
- AAL before and after photos.
- 22re stock exhaust
- Strange Whistling Noise, not when clutch is in
- Just finished my bumperrr
- Spark Knock
- 3.0 rebuild
- 4Runner Transmission Woes
- Fixed the Even Gear Shifting Problem
- alternator questions??
- clunk and grind.
- transmission noise: 87 22re 5 speed
- just fixed my idle problem i hope
- 93 pickup idle issue
- Buzzzing, whirring from engine when under load
- Need 91 PU 3VZE Help
- will v6 overheat without shroud in FL?
- New Here What Igniton U Run
- Wheel Bearing Replacement
- Tranny sound...
- Yet another oscillating idle
- Smashed front bump stops
- 87 4runner Cruise Control Problems
- Code Readers
- 88' 4Runner ( clip things...? )
- Autozone "Duralast" brake calipers, any input good or bad??
- Mountain Cop's attempt to make a soft top
- Rebuilt 22RE No Power, Tried Everything!
- air out of the gas tank ???
- -timing- on an 88 22RE
- 90 Toyota Sr5 Pickup Gear Problem?
