throttle sticking
Old Mar 24, 2010 | 04:05 PM
blackyota93's Avatar
throttle sticking
so ive been having problems with my throttle sticking when revving it in nuetral and going through the gears. its been doing it for probably a year now and is really annoying . ive taken the throttle body off cleaned it and it still does it. i think i narrowed it down to the tps or the aav valve tell me what u guys think
http://s432.photobucket.com/albums/q...t=MVI_0233.flv
Old Mar 24, 2010 | 04:14 PM
Blue_petersen77's Avatar
My idle was all screwy a while ago too. My problem was the tps. I took the tb off to clean everything and didn't have it lined up exactly when I put it back on. Luckily I left the orange paint on it, so I just adjusted it back to where the paint lined up and the issue was solved. I'd check there.
Old Mar 24, 2010 | 04:18 PM
toyota4x4907's Avatar
That seemed pretty normal to me.. You don't want the throttle to close immediately after you let off the throttle otherwise you will have too much fuel and not enough air....
All 3 22res I have owned did pretty much that.
Old Mar 24, 2010 | 04:33 PM
Junkers88's Avatar
Sounds ok but I'd look at the dashpot sticking. Mine did that for a while also and the dashpot was at fault. The dashpot keeps the throttle from "slamming" shut when you get off the pedal when shifting so that may be the culprit.
Old Mar 24, 2010 | 04:37 PM
xxxtreme22r's Avatar
to me it looks like the throttle isn't closing all the way when let go, hard to tewll though since the camera is moving too. If that's the case, I am not sure if this is normal on the re's. You could always add a return spring to it to close it faster if you don't like the way it responds. But before doing that clean the heck out of the linkage and then spray it with silicone lube and see if that helps.
Old Mar 24, 2010 | 04:40 PM
iamsuperbleeder's Avatar
I can't beleive no ones laid down the recall jokes yet... shame shame...
dash pot is what I was thinking too Junkers
Old Mar 24, 2010 | 04:47 PM
peow130's Avatar
Wrong section, you're looking for the 2010 tacoma section
Old Mar 24, 2010 | 04:54 PM
thanks for the responses guys ill see what i can do. the only real problem is when driving and shifting is when it does it the worst ill try to get another video up soon of it goin down the road. superbleeder what do you mean about the recall jokes?
Old Mar 24, 2010 | 08:11 PM
abecedarian's Avatar
Your tail pipe is on the wrong side.
Honestly, I didn't hear anything wrong, other than it has a high idle.
You open and release the throttle, the engine revs up then slows down, and hangs at about 1000 rpm's for a moment (when you get that "thwurp" sound), then drops to normal right?
Old Mar 24, 2010 | 08:17 PM
myyota's Avatar
Pull the throttle body off the intake and give it a good cleaning, chances are that will fix your problem.
Old Mar 24, 2010 | 08:27 PM
lol, nothing, carry on
pickle6415
Apr 14, 2021 06:20 AM
Shaun Crystal Gomban
Sep 20, 2015 11:16 PM
80Truck
Sep 15, 2015 04:21 PM
yoterr
Sep 15, 2015 06:26 AM
theduck21
Sep 10, 2015 07:01 PM
