22re stock exhaust
Old Mar 24, 2010 | 10:56 AM
pineapple's Avatar
22re stock exhaust
Hello~When removing the stock manifold from my 22re I just realized that I'll have to replace the little gasket on the 'secondary air injection manifold.' Can I cut one out of a sheet of gasket material I used for the fuel pump bracket or does it have to be rated for high temps? The old manifold developed the infamous crack at the 'Y' so I got a new stock manifold. Thanks in advance for any replies.
Old Mar 24, 2010 | 11:42 AM
bipolarandproud's Avatar
I think they are Designed for high heat conditions. . You need the manifold gasket and also the two exhaust flange gasket.Also the two with you talking about .. Can't think of the name ..but they should come with the exhaust gasket set .
Old Mar 24, 2010 | 12:14 PM
pineapple's Avatar
...yea, thanks. I got all of the gaskets (manifold kit) except the small one where the 2ndary mates with a pipe that curves behind the engine. Again, thanks.
Old Mar 24, 2010 | 12:16 PM
jammer1313's Avatar
yeah, they need to be the "heat" type that should have come with the set, mine did...
Old Apr 2, 2010 | 01:29 PM
Camach's Avatar
Not to bump an old thread but did you just pick these gaskets up at Autozone or something like or off the internet? I have an exhaust leak but I believe it's just the gasket.
Old Apr 2, 2010 | 01:56 PM
Just Learning's Avatar
garlock will work, but that if you have access to it we use it all the time,
Jun 1, 2021 01:51 PM
tj884Rdlx
Aug 28, 2015 12:04 PM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
1994toyota
Jul 17, 2015 03:03 AM
Nickdigg
Jul 7, 2015 06:04 AM
