idle rpm dropped all of a sudden
Old Apr 1, 2010 | 12:07 PM
jwesty's Avatar
i have a 1991 4 runner, yesterday i noticed that my rpm have gone down to about 500 at idle, and it's idling rougher. since i got it it has purred like a kitten until now. Fuel filter?
Old Apr 1, 2010 | 12:26 PM
Tubbyfatty's Avatar
You can always turn up the idle....theres a screw on the throttle body. Wait...what engine do you have?
I know where the idle adjustment screw is on the 3vz (v6) but not the 22re (I4).
Old Apr 1, 2010 | 01:28 PM
jwesty's Avatar
1991 4 runner with the 3.0
Old Apr 1, 2010 | 01:53 PM
GranVille-4crawler's Avatar
Yeah adjust your idle screw. Could be that with this recent temp change it needs to be bumped up, I don't know where you live but I'm in nc and we just started gettin hot weather and I had to adjust mine because of this
Old Apr 1, 2010 | 03:10 PM
jwesty's Avatar
I'm in AZ. starting to have big doubts about buying this thing, it seems like there might be one problem after another.
Old Apr 1, 2010 | 03:40 PM
Every car has problems. You should run sea foam in the tank and vac lines see if that helps. It could be something super simple or stupid like a tps sensor
Old Apr 1, 2010 | 03:42 PM
Also it wouldn't hurt to do plugs wires filters pcv valve. Simple tune up stuff
Old Apr 1, 2010 | 08:00 PM
Tubbyfatty's Avatar
PCV valve is a pain on the 3vz if your scared to take off the plenum.
But If you wanna turn up your idle a little bit, looking at the throttle body from the front of the truck, theres a screw, uh...ill put up a pic for ya. hold on a sec.
Old Apr 1, 2010 | 08:04 PM
Tubbyfatty's Avatar
Start the truck. Screwing it in lowers the idle, screwing it out raises it. I believe. Youll know when you do it. You want the idle to be 850-950 when warm, so make sure the engine is warmed up.
Old Apr 1, 2010 | 08:48 PM
24Runna's Avatar
How should the idle be in gear while on the brake?
Old Apr 1, 2010 | 08:58 PM
jwesty's Avatar
I also forgot to add the low rpm and rough idle is intermittent. (is that how that's spelled??)
Old Apr 1, 2010 | 09:06 PM
Tubbyfatty's Avatar
With an auto? No idea. Id set it at 850-950, put it in gear and see what it feels, sounds like.
On my manual I have my idle set at 1000. It keeps the oil pressure up a bit more, same with the alt. power.
Old Apr 1, 2010 | 09:08 PM
Tubbyfatty's Avatar
Hmmmm...id start by checkin for cracked vacuum hoses. Just go pop the hood one day and start squeezin. Also, check the intake tube for cracks. Start with the easy stuff first.
Old Apr 1, 2010 | 09:28 PM
Jay351's Avatar
Bet the intake hose is cracked. Check for air leaks! When part of my intake popped off my idle went down to 300rpm.
Sleaker
Aug 26, 2020 06:03 AM
ddg71
Jul 24, 2015 01:24 PM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
PlayAwhile
Jul 20, 2015 11:36 AM
88runnergomas
Jul 9, 2015 01:12 PM
