- 1988 Pickup Overheating
- 1st gen 4runner Issues
- ARB locker
- 87 pickup 22r wont stay running
- G52 Trans. Tech
- Sputtering engine
- Cali Legal Headers For A 3VZE
- rod knock or piston pins?
- Computer codes
- 4 runner saggy rear springs
- Power Steering Fluid Amount
- tailgate trouble
- 1st gen tailgate trouble
- 88 toyota 22re , no power?
- Truck DEAD after wiring trailer lights
- Burning rubber smell... what could it be?
- 95 4Runner Fan/Alternator Upgrade on a 3VZE
- trail gear or rough country
- 22RE idle issue - recently swapped motor...
- 95 4runner 4x4 wont engage
- Two single cab 4x4 rebuilds. 1@80% the other @95%.
- '94 Pickup Alignment question
- Clutch slipping when it's wet outside or raining
- 89 Yoter 3.0 4x4 WONT GO IN TO GEAR
- So the Story Goes... Help Appreciated!
- Exhaust
- Passenger side a/c vent
- Fuel Tank Pressure Question?
- New Dash Pot
- 88 pickup fuel problem
- Help with AC bracket
- 22RE possible coolant in oil???
- 1990 lower shifter boot
- Engine Trouble
- No clutch pedal pressure please help 89 Truck
- 22re labor rate
- Pro Comp shocks suck
- LCE Headers w/Pro Flow Exhaust on 87 PU - Not Satisified
- Fuel problem!
- 22re Compression Test - opinions?
- Need some help guys
- inconsistent oil leak
- heater core options
- 92 22RE EFI / Fuel Pump Problem
- 95 4runner exhaust
- Just towed a wood chipper home
- rattling on start and shutdown
- mud flaps
- 1988 3vze won't start
- Trouble
- Leaf swap idea
- Locking Hub Gaskets
- will 97 tacoma tailgate function on 95 pickup?
- 22RE Gradual loss of power, and then the clutch went soft, and THEN...
- need some input
- Accelerator linkage bushing?
- Fuel Sending Unit compatibility?
- Baja muffler
- White trash vacuum leak repair
- Anybody ever take apart steering column ?
- up graded ball joints and tie rods?
- Differential Guard
- What to look for on 2nd gen 4 Runner
- IFS Sqeaking
- 94 22RE rough acceleration when only when warm
- Fuel lines under cab leaking?
- fuel pump wiring help!
- Clutch, Differential, or other?
- Clutch out after starter rebuild
- 95 Xtra Cab Pickup with ADD - SAS Question
- I have a 1993 Toyota pickup 3.0 4x4 an i want to beef her up
- No Cut ZUK Mod....Tons of Heavy Add-On's....Need Advice
- Power Steerig Issue
- 1987 yota 22r
- please help- truck wont rev after mudding
- Replacing 22re soon...what to replace while its off?
- I want 1988 toyota pickup front bumper
- chevy swap ?
- alignment issue
- Is it a federal 22RE Or California 22RE
- 95 4runner check engine light / running rough
- 94 4runner ifs on 40s
- Engine builders for 22re, who to use
- 88 4runner temp gauge issue
- lift advice for 91 Toyota 4wd pickup
- 1992 pickup 22re boggy
- Towing an '84 pickup cross country with a '95 4Runner 3.0
- Transmission Leak Help- 88 5- Speed
- 86 4runner smoking/possible rings, valve seals?
- 91 4runner not getting power
- Suspension tips and help?
- 1st gen 3vze heater house rerouting (cleanup)
- Front Park Brake Cable
- 86 22r charge light and brake light on
- Help stumped on 22re warm start problem
- Warn Rock Crawler
- 1995 4runner 3.0 distributor cap wear
- 86 toyota pickup won't start
- My 3.0 is no longer slow! (throttle cable)
- Oil found on spark plug
- 93 3.0 runs sluggish then shut it off and start is again and runs great.
- Throttle body
- Need Advice on my build
- 92 4runner 4.3 swap
- No 4 Low
- fuel filter location on 97 4rr 3.4 ?
- 92 Toyota pickup
- Questions/Problems on a 22RE Front Seal
- 1993 grill on a 1990 ??
- 3rd gen manual locking hubs
- air in power steering
- 87 4x4 pickup 22r carb diagnosis and fix
- taco lift spring on 84-95 truck
- One Piece Drive Line
- 4wd won't budge wheels locked
- Extra cab rear heat mod
- 3.4 to rebuild or not to rebuild
- 95' 4runner Shifter console
- V6 radiator in a 22rte? Mods?
- Reverse won't stay engaged
- 95 3vz-e idle problem. help.
- 92 Toyota pickup 3.0V6 EFI Overheating problems- Help troubleshoot!
- Power Steering Issue
- 22re Piston hitting spark plug? Help
- nasty grinding noise
- Zuk mod, what size springs?
- First time owner, couple of questions
- Need anew radiator...ANy suggestions
- 22RE Swap Wireing Problems
- Headlight/ Electrical help
- Gear Oil Smell
- 3vz rebuild questions
- 3vz powersteering
- Recognize this decal?
- 1990 4wd issue
- Shifter Stuck in Park
- Does anyone have a '94 FSM?
- 22re alternator removal
- Chance to buy 2nd gen SAS 4runner - requesting some experienced thoughts
- brake pedal return spring
- 2nd Generation OEM idler arm
- 95 4x4 3.0vze No Power Using alot of Gas
- R.I.P. 1987 4Runner
- Good Or Garbage ??
- Unfortunate Clutch Issue
- 1987 toyota pu runs like crap
- 3.0 to 3.4
- 89 4x4 pichup front bumper build
- Power loss & smog fail
- 88 v6 SR5 Toyota pickup starting problem
- 88 pickup 22re surging
- 87' Toyota Pickup Timing Issue
- Head Gasket Recall (
- Few 1st Gen 4runner questions
- Rebuild 22re or swap for more?
- A few newbie questions for 3vze reassembly
- All headlights and driver's side lights out! '88 pickup 22r
- Arb air compresser where to mount it ?
- Where to buy rebuilt 22R?
- Converting 22RE to 22R
- Rekeying?
- Dash light
- 87 22r wont start!
- Need chose between 88 truck and 93 truck
- 87 p/u goes elect dead after warmup, store stop then restart attempt
- distributor help!!
- Need help with 91 pickup odd issues....
- Rear sliding window 87 standard cab
- 22re squeal after installing new injectors
- 1988 Pickup 3.0L Leaking Radiator Fluid
- .20 .30 .40 over ??? Any perks?
- 92 22RE difficult to start when engine warmer
- 88 22re OE cam
- 89 v6 fuel pump/starting problem
- 22rte CT26 turbo swap
- Low idle, idle screw all the way out.
- Headers/O2
- lights flash at high rpms and no radio memory after crank
- Water not circulating!
- Toyota Chinook?
- Anybody plasti dip chrome bumper and grille, long term durability?
- Help with O2 sensors
- Tranny Leaking Coolant
- clunk after procomp lift
- What is this?
- 22re died while driving
- CEL Code for Leaking/Loose Gas Cap or Filler Hose?
- lost in Africa with a LJ73 - does not crank
- Bearings
- Rear Anti Lock light
- Replace camshaft plugs ?
- ODO/Trip meter quit working
- 94 22re vss?
- Diesel Swapout - 86 22r to Cummins 2.8
- Clutch Repair gone wrong
- Lockouts
- Injector rebuild kit? Or new injectors?
- 1988 4runner idle issues
- Heater and A/C control assembly
- 92 4runner drive train lubricant swap
- Simple question
- Heater delete help/imformation???
- 1993 T100 lower control arm
- 1994 3vze flamethrower injector issue
- 4x4 front wheels not engaging, but just human error.
- 22RE sputtering problems
- starter not working.
- Need help finding a leaking fuel line
- Chevy stepside bed on a 1986 Toyota 4x4
- Rear Aftermarket Leaf spring reviews
- Another 3.0 Low Idle/Stalls When Warm thread...
- 1989 v6 dizzy cap and rotor arm
- Truck died in snow storm
- Just thinking
- 5 speed swap
- Aftermarket Stereo Wiring Questions....
- No Power to Aftermarket CD Player
- Help
- No Power Steering After Highway Driving
- Battery Indicator Light Flickers On/Off, Headlights Surge Bright/Normal
- Windshield wiper motor
- MD's 1990 4Runner Headgasket/TC rebuild
- 3vze all of a sudden fell on face...
- High impedance injectors in 87' 4Runner?
- CVC Joint
- Wont start, Fuel guage,pump issue?
- Another clutch question
- Anyone use MT-85?
- Bench to bucket
- fuel filter advice/ fuel pump?
- First Tune up
- head gasket replacement
- Noise while driving uphill
- Dual Weber Carbs on a 22R?
- Can't remove 22re pulley bolt, tried all methods I know of
- coolentmania! or My Leaky Throttle Body
- Interior compatability between 2WD and 4WD?
- my old yota towed a truck home
- What is this?
- 93 4Runner seemingly has no spark to plugs
- 1986 Toyota
- No clock memory nor dome light
- ignition lock switch..
- A340 with gear transfer case issue
- Rear mud flaps ideas
- Flat leafs
- Marlin Crawler short throw shifter
- bad truck. dies. runs like crap. jerks alot.
- OME rear leafs or 63" chevys?
