3.0 to 3.4
Old Feb 11, 2014 | 03:49 PM
Toyo03's Avatar
3.0 to 3.4
Where do I start on doing this swap? I've got a 94 with 195,000. Head gaskets replaced at 189,000. Want to find a 3.4 and swap out soon. Anyone in arkansas that could help on where to find an engine and harness? Do you recommend buying a used one from pick n pull then tearing it down replacing all? Any advice would help thanks
Old Feb 11, 2014 | 03:53 PM
Inferno451's Avatar
Welcome to Yotatech! Try using the search function, there are many, many, many, MANY threads about doing this very thing. There's even an entire engine swap section of the forum.
Old Feb 14, 2014 | 06:31 PM
California's Avatar
Search function works well, there's a wealth of knowledge on here.
Here's a few links to help you get started:
https://www.yotatech.com/forums/f160...-101-a-239002/
http://www.offroadsolutions.com/tech...fe-conversion/
http://66.95.100.204/test/3.4%20Swap...g%20Theory.pdf
http://www.pirate4x4.com/forum/toyot...yota-swap.html
Hope this helps.
Old Feb 15, 2014 | 02:09 AM
wyoming9's Avatar
Red face
Start reading all the sticked threads in the 3.4 swap section .
After your done with them you can ask better questions!!!
Old Feb 15, 2014 | 10:04 AM
BigBluePile's Avatar
Unpossible swap. You'd be the first.
Old Feb 15, 2014 | 12:25 PM
wyoming9's Avatar
Red face
Unpossible ??
Old Feb 15, 2014 | 06:20 PM
dntsdad's Avatar
Find a wrecked vehicle and buy it. You can sell the excess parts. I made a profit of the runner I bought for my swap. Do not try to piece it together by buying separate parts in my opinion, especially since your knowledge of this seemingly is about zero.....no offense.
Read the threads above. You can also read mine in my signature. I started with zero knowledge and had to learn quick when my 3.0 spun a rod bearing. I read for months and then thought I had a handle on things......then the real work started and I realized I knew about 10% of what i thought I did.
I have two under my belt now and still don't know everything.......but I can get it done.
Like anything else, the majority of the work is in the research.
Amer
3.4 Swaps
19
Jun 5, 2017 10:43 AM
sphealy
Sep 3, 2015 07:55 PM
ashersullivan88yota
Aug 19, 2015 06:00 PM
Valvoman
Aug 8, 2015 03:52 PM
93toyoguy
Aug 2, 2015 07:41 PM
