1990 lower shifter boot
Old Feb 23, 2014 | 04:21 PM
sleeper bird's Avatar
i did try to search and find this out ,and i searched marlin crawler as well,anyway i was going to change the shifter bushing on my 1990 5 sp and realized the lower boot has seen better days,torn in half im assuming to do it right i should change it.On marlin crawler they just listed the 80s model none for the 90s,would anyone have a part number or description of the boot?or do you have to buy the whole assembly - flange that mount to the transmission?
Old Feb 24, 2014 | 07:03 AM
fdp101452's Avatar
I bought one about a year ago from Toyotapartscenter.net for my 90sr5. Don't remember the number but you can just call them and they can get you what you need.
Old Feb 24, 2014 | 07:38 AM
scope103's Avatar
Not having a manual, I'm not entirely sure what the "lower" boot is, but this site has drawings, part numbers, and will sell you the part.
As usual, you will get much better results if you use your VIN. That will pick out the correct model for you.
Old Feb 25, 2014 | 02:30 AM
its the small boot that covers the transmission stick shift internals,keeps dirt and all out of the transmission.Another question i had was that i noticed that on the breakdown there was only one bushing,the larger bushing that marlin crawler sells is not listed.Is this something that marlin added that was not factory,or did some models not have that setup,with the marlin crawler design per say.
Old Feb 25, 2014 | 03:22 AM
the ball seat is what i dont see on the parts breakdown,the only thing that i see on my truck is a round rubber washer,is that considered the ball seat from toyota?
Old Feb 25, 2014 | 08:31 PM
Punchy's Avatar
You can get the trans shifter boots from Toy dealer still, I got both for my R150F for less then $20 together.
part 33555-20060, I don't know if this is the main stick or tranfercase and cant find the other label.
They both installed with ease using Astroglide.
Old Feb 26, 2014 | 02:11 AM
i found it thanks alot for the help,astroglide huh
Old Feb 26, 2014 | 08:15 PM
94 SR5 Mountaineer's Avatar
When I installed my MC ball seat there was no stock part there like it; just the rubber ring. I assume this is how they all are. When you install the new seat you can pitch the old ring.
Old Feb 27, 2014 | 02:28 AM
that answers what i was wondering,thanks alot for the replys on this.
Old Feb 27, 2014 | 08:24 PM
Punchy's Avatar
You try sliding those boots over the stick with out lube and a good chance or tearing them.
Astroglide is waterbase and evaporates.
Old Feb 28, 2014 | 02:26 AM
i know do know what astroglide is,but i never thought to use it on any of my mechanic projects.i just thought it was funny as hell to see astroglide used for this.Good thing i have some so im good.
Gone Fission
Oct 28, 2015 10:28 AM
Ryall
Sep 2, 2015 06:48 AM
Scarbéli
Aug 23, 2015 03:22 PM
Gone Fission
Jul 24, 2015 12:49 PM
ptb12
Jul 5, 2015 01:49 PM
