need some input
Old Feb 22, 2014 | 06:36 AM
KBar's Avatar
need some input
So I'm finally gonna replace my 22re cam with a engnbld 268, and throw on a header but I'm kinda lost at the cat and muffler. Live in mississippi so no emissions laws. So I'm thinking no cat and maybe a thrush turbo exhaust. This is setup will bring some pep back to my 86 1stgen?
Old Feb 22, 2014 | 07:58 AM
wyoming9's Avatar
Red face
Big $$$$ for so very little gain.
I hope your not really expecting much as far as gains
What kind of Compression do you have ?? How many miles??
I love my
22 REC engines but they are what they are.
Old Feb 22, 2014 | 08:12 AM
Inferno451's Avatar
I'm convinced any investments in performance gains on this motor are a waste. I saw ZERO improvement after adding a 261C cam and 2 1/4 inch exhaust. Save your money and keep it stock. If you look at the numbers between the stock cam and the ENGNBLDR cams there's only a very small difference.
Old Feb 22, 2014 | 09:52 AM
BigBluePile's Avatar
Good plugs, cleaned injectors, supra AFM, big bore TB, custom air intake box, 4 into 1 header, and 2.25/2.5" exhaust with hiflow muffler.
Boom.
Old Feb 22, 2014 | 11:16 AM
Inferno451's Avatar
^^Says the guy with a 3.4 swap . That's what i would save my money for.
Old Feb 22, 2014 | 12:10 PM
wyoming9's Avatar
Red face
Thing is you can put as much money as a 3.4 swap into the head of a 22REC engine and still be at least more then 50 horse power from the stock 3.4.
Then if you want to build your 2.4 just get the whole new head with the over size valves the cam all ready ported and polished .
The 4 into header into a 2.25 exhaust with free flowing muffler .
That will give you about all your going to get on a normally aspirated engine
Old Feb 22, 2014 | 12:58 PM
KBar's Avatar
im tired of going super slow up hills and bridges. I have about 120 -130 psi
Old Feb 22, 2014 | 01:18 PM
wyoming9's Avatar
Red face
In your case gears might get you more of what you want.
I just hate to see people spend money only to not like the results they ended up with.
Be nice to be able to drive the end results of someone doing what your thinking about
Old Feb 22, 2014 | 02:19 PM
Sounds like a different set of gears would help.
Old Feb 22, 2014 | 03:07 PM
KBar's Avatar
I already have 4.88 gears
Old Feb 22, 2014 | 03:32 PM
Inferno451's Avatar
Then you're looking at forced induction or an engine swap. You just are not going to get much more power out of that motor without some serious modifications.
83yotastockR
11
Nov 10, 2015 06:54 AM
zanzabar0
Oct 11, 2015 02:56 AM
hiluxinargentina
Sep 30, 2015 11:12 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
beltcutter
Sep 30, 2015 06:14 AM
