Heater delete help/imformation???
So I'm debating on ditching my heater all together.
As far as the metal tubes, one bolting to the lower intake manifold and the other to the backside of the timing cover. Should I keep those on the motor and just connect the two open ends with a rubber hose, basically making the coolant bypass the soft heater lines going into the cab. Or should I just make so plates that's I can just bolt down over the openings on the intake manifold and timing cover. How that makes sense.
Travo
Travo
Don't just connect them together. A friend of mine did that and he couldn't figure out why his coolant temp would creep up and eventually overheat.
With the heater core in the loop it at least dissipated some heat. With just a loop it is a significant amount of coolant just bypassing the radiator.
best place is to eliminate it at the heater control valve .. shorten the pipes from there . This way you will have NO issues with overheating . just make sure your thermostat is good
kawazx636
Oct 6, 2021 03:03 PM
WTB[PacNorWest]: Old Man Emu Torison Bars
A2theK
Oct 14, 2015 07:10 AM
gyroscope7
7
Sep 27, 2015 08:39 PM
