Heater delete help/imformation???
Old Feb 5, 2014 | 05:02 PM
totalchaosyota92's Avatar
So I'm debating on ditching my heater all together.
As far as the metal tubes, one bolting to the lower intake manifold and the other to the backside of the timing cover. Should I keep those on the motor and just connect the two open ends with a rubber hose, basically making the coolant bypass the soft heater lines going into the cab. Or should I just make so plates that's I can just bolt down over the openings on the intake manifold and timing cover. How that makes sense.
Travo
Old Feb 5, 2014 | 05:19 PM
Inferno451's Avatar
Maybe the cold weather is making me biased, but what in the world do you have to gain by bypassing your heater? Do you understand you won't have a defroster any more?
Old Feb 5, 2014 | 05:22 PM
aztoyman's Avatar
Don't just connect them together. A friend of mine did that and he couldn't figure out why his coolant temp would creep up and eventually overheat.
With the heater core in the loop it at least dissipated some heat. With just a loop it is a significant amount of coolant just bypassing the radiator.
Old Feb 5, 2014 | 06:47 PM
slacker's Avatar
best place is to eliminate it at the heater control valve .. shorten the pipes from there . This way you will have NO issues with overheating . just make sure your thermostat is good
Old Feb 5, 2014 | 07:36 PM
Punchy's Avatar
Again why?
Old Feb 5, 2014 | 07:51 PM
The truck is purely for the desert toy/ race truck. I want it to have the amount of moving parts and places to fail as possible
Old Feb 5, 2014 | 07:55 PM
What if I just plated the openings, that way no coolant will bypass the radiator. Is that something that will work?
Old Feb 5, 2014 | 09:24 PM
Robert m's Avatar
Jeff?
Old Feb 5, 2014 | 09:29 PM
Gevo's Avatar
After I rebuilt.my engine I had my heater hoses bypassing the core for a little while. Its not a big deal. The coolant will still circulate.
If it is not broken.. dont touch it!
Old Feb 6, 2014 | 10:27 AM
aztoyman's Avatar
Blocking them off would be the same as closing the heater valve. Should be fine.
kawazx636
Oct 6, 2021 03:03 PM
A2theK
Oct 14, 2015 07:10 AM
woodyth
Sep 30, 2015 06:32 PM
gyroscope7
7
Sep 27, 2015 08:39 PM
