First Tune up
Old Feb 2, 2014 | 05:25 PM
Treez94yota3.0's Avatar
First Tune up
I just bought my first Truck and Toyota a few days ago its a 94 xtra-cab 4x4 3.0 liter and I plan on doing a tune-up right away . Whats the best Oil,plugs,and wires that I should use ? Should I just use stock recommendations . And what Oil,plugs,wires should I stay away from ?
Old Feb 2, 2014 | 07:41 PM
Stetson_md's Avatar
Go with valvoline oil and enroll in the free engine warranty if your truck is under 125k miles, ngk plugs set the gap to factory spec (.032?), bousch or AutoZone plug wires cause of the lifetime warranty. Get the correct oil weight for your climate. Otherwise try to stay with thw stock specs
I personally don't like gtx oil
Old Feb 2, 2014 | 08:25 PM
Gamefreakgc's Avatar
Here you go:
http://personal.utulsa.edu/~nathan-b...intenance.html
You're welcome. Don't forget to lube the chassis and drive shaft with a grease gun.
Old Feb 4, 2014 | 10:08 AM
Thanks. I'm gonna go with ngk plugs,bousch wires, and Vavoline Max Life Oil . Next is to figure out why my Heat works when it wants .
Old Feb 4, 2014 | 10:20 AM
buickid's Avatar
The OEM Toyota plug wires are affordable (ToyotaPartsZone) and high quality, and come with all the clips that hold them on the engine (already clipped onto the wires too!)
Old Feb 4, 2014 | 12:33 PM
Stetson_md's Avatar
NGK V-Power BKR5EYA (2087)
This is the exact plugs you want
ladybugRC
458
Aug 21, 2020 10:41 AM
MadMax48
Mar 3, 2020 10:33 AM
urabus
Nov 10, 2015 07:38 PM
the_supernerd
Oct 1, 2015 09:20 PM
