PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 [212] 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267
  1. What starter will fit my truck?
  2. Truck won't start
  3. 86 22RE Timing Chain
  4. Bad vibration from engine under 1500 RPM's
  5. new 3.0 1KZ-TE (turbo diesel) on eBay!
  6. Valve Cover Gaskets
  7. Feel That Power....not!
  8. IFS Diff Disassembly
  9. SDS install
  10. ideas for 2 inch lift
  11. My truck is making a dieseling sound/alot of ticking
  12. Crystalization in Iowa
  13. Trouble codes 24, 31
  14. 1990 Truck and 4Runner Axle Interchange
  15. Wanted
  16. TRUCK SHAKES WHEN IN 4WD, Help
  17. Black smoke and then it died
  18. Question regarding timing....
  19. seats ad removable steering wheel -
  20. A few issues.
  21. 4Runner Passenger seat question
  22. Snow Pics!!!
  23. manual vent door to power no vent door? ahhhhhhh! questions!!!
  24. Trucks pulls to the right in 4wd only?
  25. Dual Valve T-stat issues.
  26. Beat em' up Truck picture post
  27. short block 22re
  28. Body lift + Gear Shifter Problem???
  29. TPS Fault and Tranny issues
  30. Removing front shocks the easy way
  31. 94 4runner needs some help!!
  32. new STOCK!!! leaf springs for an 86 4runner
  33. enginbldr timing chain
  34. help tranny/clutch on my dd and i need to fix it
  35. noise???
  36. Intermittent Reverse Lights Help!
  37. My key stopped working
  38. 1986 Toyota 4x4 pickup transmission issues
  39. Please help head gasket.
  40. Need help FAST!sold tires..kid wants $$ back
  41. Suspension upgrading
  42. URGENT!!! cold weather idle problems
  43. new motor no power?
  44. carb pics!
  45. Runs rough on start up...
  46. Door Locks
  47. Leaking Transmission Lines
  48. Overcooling
  49. Power steering Air Control Valve
  50. 3VZE Starting "Malady"--Does This Affect You?
  51. A question for the Diesel guys....
  52. Dome light only works with ignition?
  53. hard warm up
  54. 3.0 ecm 89pick-up/93 fsm
  55. Gassy gas tank mess...need insight
  56. 240sx seats in 94 pickup
  57. Whats the tool called? bleeding brakes/slave cylinders
  58. OK guys, here it is!
  59. Clutch Catastrophe?
  60. 91 4Runner..The worst fuel economy in the world.
  61. Is it my valves?
  62. lean
  63. Running E85 in my 88 22re
  64. GLOW AM1 Relay - Part# Anyone?
  65. Can Someone Help Me Decode my Door tag information?
  66. that intke from downey
  67. 89-95 4wd grille pics please.
  68. 7M gas mileage
  69. 22RE loping idle fix
  70. simple saturday projects are awesome
  71. Seat belt help
  72. fluid specs.
  73. Body Lift
  74. A Smoking Hot Deal On Ebay
  75. antenna troubles...
  76. Loose shifter? How to tighten?
  77. E-Bay! Does anyone know if this is for real???
  78. New truck/ first upgrades??
  79. o2 sensor replacement,scan tool
  80. Any Ethanol alternatives?
  81. Thinking of selling my truck trying to get idea for price range
  82. 3vz-e help
  83. 4.88, I think I have this right?
  84. por-15
  85. 90-95 4 Runner Buying Info Needed
  86. license plate light removal
  87. Inside panel part # needed
  88. Brake Variations
  89. 3.0 bucking/hesitation
  90. wish wash
  91. Front bumper update II
  92. AFM Modification
  93. Need Help Wont Start
  94. anyone use there stock yota ac for on board air?
  95. 4 runner is dying
  96. reading the trouble codes
  97. Coil to Leaf spring conversion on '91 4Runner??
  98. Where to buy tires near bay area ?
  99. no go juice
  100. TPS ?'s on a 91 4runner
  101. My front end needs a rebuild
  102. new toy ota that is
  103. Starter Solenoid
  104. Pace setter exhaust?
  105. Engine Install In 91 Runner 3.0
  106. Breathers
  107. This Weekends Project
  108. 7.5 to 8 inch swap
  109. How much have you spent on regearing?
  110. Spark Plugs
  111. 3.4 swap - ORS Crossover- CA Smog
  112. Feeling drag with hubs locked but in 2WD?
  113. coil/igniter- test help needed
  114. 22RE fluctuating idle+ auxiliary air valve
  115. multi color led gauge lights
  116. Got siped today!
  117. 8mm plug wires
  118. 89-91 Toyota 4wd Trucks
  119. 4runner side mirrors
  120. need pics
  121. Putting my front mud flaps back on. Hardware?
  122. Do Not Ever Order From These People!!!
  123. Interior condensation?
  124. My 4-runner is history : (
  125. 88 yota ruff idle an acceleration
  126. Replacement door/ign keys
  127. SAS parts opinion
  128. 92 3vz oil leakage question
  129. Cold start problem...one tow already this winter
  130. Ifs Swap
  131. Body parts compatability?
  132. No Pressure?
  133. brakes/alignment troubles
  134. thanks to everyone who helped
  135. How many times you replace HG?
  136. not idling
  137. Engine cutting out???
  138. please list the fuse block numbers- 88 4x4
  139. E-brake adjusting
  140. Starting problems :(
  141. Poor ebay listing
  142. i need help on a transmission number
  143. Finding a short,on the tailight,dashlight,trailer light curcit!
  144. What is this ticking?
  145. Just ordered Marlin's S-HD Clutch
  146. How do aftermarket cams make power?
  147. knock sensor killing MPGs?
  148. Alternators for 22R-E
  149. Jounce or Air Bumps on Total Chaos LT
  150. need engine block heater or ?......22re
  151. a tps story...
  152. New Meats
  153. MPG + or - w/ Engnbldrs 261C
  154. 1990 4Runner Electrical
  155. the overzealous starter...
  156. I Need HELP!!!
  157. bolt size question
  158. Engine\tranny removal Question...
  159. Rain killed my truck ????????
  160. Front end rebuild
  161. who knows this one?????
  162. Heater/AC backlight
  163. 3.4 swap - Don't get 5VZFE with EGR
  164. need help vibration
  165. tail light gasket
  166. tensioner/idler pulley cheap fix?
  167. manual hub donors
  168. What prblms will yield blow-by
  169. Broken timing Belt?
  170. check engine light and engine studder?
  171. 261 rv cam
  172. Bj spacer's
  173. swapped motor and now it runs like crap
  174. no heat
  175. nor cal shop to do SAS?
  176. valve adjust ment for cold?
  177. 22RE 5spd with 37s and 5.71s on the highway?
  178. crappy gas mileage forever
  179. Factory 4.88's
  180. point me in the right direction...PLEASE?
  181. Weird Noise In Steering Colum
  182. 3rd member swap...will it work?
  183. 3.0 code12 and 51 can't start my 89
  184. my girls turning 100K!!
  185. Bj Spacers and Front shocks
  186. 3vze frost plugs or...
  187. timing belt kit.. is one better then the other??
  188. Auto Transmission Problem Only When Cold
  189. Charge, Brake, and AT Oil Temp lights, no help from alternator.
  190. Finally got the sliders mounted!!!!!
  191. ran fine this morning need help now!!!??
  192. HUBS locked in while driving? far distances
  193. i hate 4wd brakes
  194. 4WD Shifter and Transfer case problems
  195. axles questions
  196. no power to heater relay
  197. auto tranny problems
  198. quick question, whats the bolt for on the oil pump?
  199. Troubleshooting my ignition
  200. ~PLEASE HELP~ Best body shop in Dallas Ft.Worth
  201. Will you guys check out my butt pleeeease
  202. 91 4Runner Instrument Panel
  203. Ebay find: High Output 3vze
  204. Ironman Suspension
  205. delayed shift into reverse
  206. My Runner at Azusa this weekend
  207. Heat/defog
  208. Ignitor compatability
  209. Heater Core Install 88 Toyota Pickup
  210. Shop in/near Lakewood, CO to deal with LSPV
  211. Let there be lift!
  212. Hendrix Motorsports Carrier Bearing Support
  213. 22re...poor/no acceleraton
  214. E-Brake Cabke questions
  215. i saw the strangest toyota today
  216. Clutch advice
  217. idle up vacume hose???? anyone got a pic of there carb?
  218. 86 4Runner Blowing Black Water out exhaust
  219. BJ Spacers
  220. What do you guys think about this!
  221. Gear Oil Opinions
  222. Front leveling kit?
  223. squeaking speedometer
  224. Tru trac swap
  225. HG Replacement questions
  226. I Need Help Vibrations
  227. Help!!!!!
  228. Read End Binding
  229. real quick -- benefits of AISIN, WARN, etc manual hubs?
  230. what camper shells will fit my 94 sr5
  231. code 25 & 26 after new headers...help!?
  232. TACOMA750s....Heated seat build!
  233. how do i disconnect the tie rod?
  234. Good Denver Craigslist Find
  235. Q for the Aussie members...
  236. tire sizes
  237. weird noise/ problem (95 3.0L) pictures
  238. Snow/Poser Shots.
  239. BLEEDING BRAKES (What the hell am I doing wrong!!!)
  240. Key won't come out of ignition
  241. Will OME 892 HD coils fit a 1990 4runner??
  242. fan/blower/switch stopped functioning
  243. any idea why my alternators keep failing??
  244. Locker Suggestions Please.
  245. what kind of car is this
  246. compression
  247. Upgradeing 1989 4Runner
  248. OME 2 inch kit advise help
  249. A little engine swap info needed.
  250. Valve Cover tightness
