i hate 4wd brakes
Old Dec 5, 2007 | 08:58 AM
doubledizzle's Avatar
i hate 4wd brakes
ok my rigs killin me! just did a front brake job on it and now when i hit the brakes the brake light in the dash comes on.....ive checked all the fluids and bleed them over and over again its not goin away.! if anyone has any idea please let me know somthin i put new rotors calipers and pads on so?
Old Dec 5, 2007 | 09:15 AM
mt_goat's Avatar
What bleeding method are you using?
Here's some good info on the different types:
http://www.gadgetonline.com/BrakeFlush.htm
I've never had a problem using the Power Bleeder.
Old Dec 5, 2007 | 09:51 AM
TORTIS's Avatar
see if the float is stuck in the MC
Old Dec 5, 2007 | 10:18 AM
MMA_Alex's Avatar
could also be the e-brake sensor
Old Dec 5, 2007 | 10:40 AM
GV27's Avatar
AFAIK, there are two and only two switches that light is connected to - your e-brake switch (on the firewall - rod hits it when all the way down) and the fluid level sensor in the MC. For the handbrake switch just make sure it's not flopping around - hard braking would tend to drive the rod farther onto the switch so that part probably isn't the problem. But I would guess it's the level sensor in the MC. Make sure fluid is up to the "full line", that sensor plunger isn't sticking (as mentioned) and that wiring for it is good.
There's no sensors down on the pads or air sensors in the lines or anything like that.
Chris
Eggslinger
Jun 8, 2019 03:32 PM
jasonty
41
Dec 23, 2018 01:00 PM
genuinegemini
Aug 3, 2015 04:56 PM
ripp96
Jul 31, 2015 11:14 AM
ripp96
Jul 25, 2015 02:32 PM
