Suspension upgrading
Old Dec 10, 2007 | 02:59 PM
f4stunna's Avatar
i recently ordered a OME complete suspension lift kit (without torsion bars) and ball joint spacers...
the suspension is pretty beat in the entire truck, which is why i wanted to get new shocks and leaf springs.
i went today and ordered upper and lower ball joints.
anything else i should replace while i have it all torn apart?
Old Dec 10, 2007 | 03:21 PM
davenjai's Avatar
First put your rig, in your sig. I would do the whole steering rack, sway bar and CV boots as well. Basically anything rubber.
Old Dec 10, 2007 | 03:39 PM
f4stunna's Avatar
91 4X4 22RE standard cab short bed
at the moment stock except for the 31's on it and the bucket seats i put in this last weekend
Old Dec 10, 2007 | 05:28 PM
f4stunna's Avatar
so what is the steering rack?
the lift kit is coming with a new sway bar
im new to the truck thing, although i can strip down and rebuild a modern street bike and build it from the frame up no problem
Old Dec 10, 2007 | 05:46 PM
AxleIke's Avatar
You don't have a steering rack. You have a pitman/idler/center link set up.
I would replace the Tie rod ends, and adjuster sleeve. I would leave the CV boots alone, unless they are leaking.
I'm surprised you are getting a new sway bar. That is very uncommon in lift kits. What is wrong with your current one?
Old Dec 10, 2007 | 05:55 PM
f4stunna's Avatar
my bad, i ment steering dampener...
Old Dec 11, 2007 | 02:29 PM
f4stunna's Avatar
so is it worth doing tie rod ends?
anything else i should do?
and what is the adjuster sleeve?
Old Dec 11, 2007 | 05:46 PM
f4stunna's Avatar
bump....
im going tomarrow to pick up the ball joints so its pretty much last chance if i need to order something for it to be here for the weekend
Old Dec 11, 2007 | 08:09 PM
AxleIke's Avatar
adjuster sleeve goes between the two tie rod ends. The only reason to replace it is that they get really rusted, and it makes removal and install much easier, plus they are like 10 bucks. I would just do those since they are fairly cheap, and you have to get an alignment anyway.
They aren't necessary or anything, unless they've gone bad, just nice to do.
Old Dec 11, 2007 | 08:14 PM
f4stunna's Avatar
so anything else along with the bj's, tie rod ends, and adjuster sleeves?
Old Dec 11, 2007 | 08:18 PM
CoedNaked's Avatar
What about a steering stabilizer? OME apparently makes a pretty decent one.
Also, how is the play in your front steering? You could need a new idler arm. Idler arms and ball joints are the main wear items on these front IFS suspensions. Get a good alignment done while you're down there.
Old Dec 11, 2007 | 08:31 PM
f4stunna's Avatar
i got the steering stabilizer with the OME kit i bought...
so the list is up to:
ball joints
tie rod ends
adjuster sleeves
idler arms
Old Dec 11, 2007 | 08:50 PM
AxleIke's Avatar
Looks like a good list. The idler is going to cost you, but it is good to do as well. Again, not necessary unless its bent, but good.
justdifferentials
Just Differentials
Jun 13, 2022 07:40 PM
Scottcrb
Mar 3, 2016 11:57 AM
Lons81
Nov 23, 2015 09:25 AM
sonorn67
Sep 19, 2015 05:39 PM
justdifferentials
Sep 5, 2015 06:52 PM
