TRUCK SHAKES WHEN IN 4WD, Help
Old Dec 11, 2007 | 04:33 PM
keithguts's Avatar
When I put the rig into 4WD, it seems to vibrate when I'm driving. Also it is at any speed. Any Idears of the problem.
It is a 1995 4x4 4runner 3.0.........................
Old Dec 11, 2007 | 04:37 PM
thook's Avatar
Are you driving on pavement?
Old Dec 11, 2007 | 04:46 PM
keithguts's Avatar
Yes, very wet and slussy roads when I noticed it. It also does the same on dry roads. I don't use the 4wd on dry roads, but I just checked it to see if it did the same as it did on the wet roads.
Old Dec 12, 2007 | 10:52 AM
keithguts's Avatar
Any one here to help please!!!!!!!!!!!!
Old Dec 12, 2007 | 11:16 AM
jason191918's Avatar
front u joints/bearings?
Old Dec 12, 2007 | 11:42 AM
Tacoclimber's Avatar
ADD or non ADD?
Old Dec 12, 2007 | 12:02 PM
bigarms23's Avatar
check you u-joint but also have your driveshfts balanced and make sure your steering is tight
Old Dec 12, 2007 | 12:35 PM
04 Rocko Taco's Avatar
EASY question....what size tires are you running? Is the exact same front and rear?
Old Dec 12, 2007 | 12:49 PM
isaac338's Avatar
u joints, bearings (diff and wheel), bent drivehshaft, screwey hubs, it's obviously something in the front end so get down there and start a-pokin
mtrdrms
Jul 17, 2015 02:23 PM
YotaGreenhorn
Jun 27, 2015 07:00 AM
TheManOutside
Jun 18, 2015 03:32 PM
LV_4Runner
16
Aug 5, 2002 11:35 AM
