Truck won't start
Old 12-12-2007, 08:45 AM
yotakid825's Avatar
Unhappy Truck won't start
I had to pop-start it to get it home last night. It doesn't even crank over, when I 'hit' the key all it does is click. Sounds like the starter is clicking. Starter toast?
BTW I have a '94 pickup with the 22re and a 5spd.
Old 12-12-2007, 08:46 AM
jason191918's Avatar
sounds like a starter or solenoid.
keithguts's Avatar
Ya, sounds like the starter to me, but you might want to clean your battery connections as well. Bad connections will also cause this to happend.
Old 12-12-2007, 08:49 AM
4Crawler's Avatar
Here is a simple voltage check you can do to help isolate the cause of the no-start problem:
http://www.4crawler.com/4x4/CheapTri...shtml#EasyTest
Old 12-12-2007, 08:50 AM
Myron's Avatar
This happened to me this morning. Went to start it, and would not turn over. Can hear the fuel pump kick in, and the starter would click, but would not turn.
And its not the battery. So let me know what you find out on yours.
Old 12-13-2007, 04:41 AM
yotakid825's Avatar
I seemed to over look the clearly obvious the battery cables were almost falling off. man I feel dumb
Crazychris1871
06-27-2016 10:38 AM
Cesarl74
04-23-2016 06:07 PM
newzingo
06-24-2015 01:50 PM
slider417
06-22-2015 10:18 AM
Corey
06-10-2002 04:23 AM
Quick Reply: Truck won't start
