Clutch advice
Old Dec 4, 2007 | 09:45 AM
Gavy's Avatar
Clutch advice
Hey guys I have a friend who is willing to do my clutch and flywheel for a few bucks and I need opinions on which clutch to get I know Marlin and Centerforce are popular but my truck is almost strictly a DD and I wnat to know what route would you guys go to get a durable reasonable priced clutch thanks
Old Dec 4, 2007 | 09:56 AM
Georgiadave's Avatar
I have a Centerforce, it has been OK. It works on centrifical force (RPMs) and I'm not sure it was worth the money for my 22RE. I think Marlin would be as good a solution for less money.
Old Dec 4, 2007 | 10:54 AM
black diamond's Avatar
i would stay away from from the centerforce, marlin has many different types, choose whats best for your DD. u can"t go wrong w marlin. good stuff.
Old Dec 4, 2007 | 12:44 PM
TNRabbit's Avatar
^Ditto: MarlinCrawler is top notch and reasonably priced.
Old Dec 4, 2007 | 12:55 PM
fillsrunner4's Avatar
Marlin
Old Dec 4, 2007 | 12:56 PM
TORTIS's Avatar
as much as i hate to say it, marlin. don't bother paying for express freight, it will still take a week to get it.
Old Dec 4, 2007 | 01:48 PM
idanity's Avatar
i just did mine w/'Deathcouger" and we used a OEM Toyota, and all i gotta say, the toyota is nice.
it drives nice, and it lined up perfectly w/out the tool (DC did that though), remember you need the matching tool.
pretty big job, but we did it in 4 hours
also did
pilot and throwout bearings (need a pilot bearing removal tool too- the grease trick didnt work, as it oozed out the broken bearing).
tranny rear seal, (did that a week before)
main block rear seal
for a dd, i would recomend a easy/soft clutch.
i romp mine, and the oem does fine.
Old Dec 4, 2007 | 01:59 PM
TORTIS's Avatar
also did
candle wax works like a champ
Old Dec 4, 2007 | 06:22 PM
thook's Avatar
I don't know....the Marlin 1200lb'r is pretty damn acceptable for a DD. Especially with a new master cylinder......thanks to Tortis. (Cheers, mate. How's the camping been? I've been swamped...as usual.) Oh, and I adjusted the pedal height. Made a big difference, too.
Anyway, 900ft/lbs is the OEM rating. Anything Marlin or WabFab (both Aisin/Seiki = OEM) has in that rating is superb....at less than Toyota cost.
(Edit:Ooops... Marlin doesn't off the OEM style.)
Old Dec 4, 2007 | 06:27 PM
Jay351's Avatar
I would go with the marlin. Great kit. Also pick up the shifter seat and bushing.
Old Dec 5, 2007 | 01:28 PM
dlbrunner's Avatar
I just got the marlin unit, will be installing this weekend.
they are on sale too! $150 shipped to my door and the HD flywheel bolts
Old Dec 5, 2007 | 02:13 PM
CyMoN's Avatar
I bought one from wabbit and I have no complaints.
it is a asin seco one
Old Dec 5, 2007 | 08:55 PM
gametom's Avatar
i just got a napa kit last month under 100 for the clutch kit and 50 for the flywheel. i love it
Old Dec 5, 2007 | 09:08 PM
CoedNaked's Avatar
I would get the Aisin stock clutch from Marlin (900 pounds or whatever) Or an OEM Toyota clutch, which I believe are one and the same, if not very similar from what I have heard.
It always makes me wonder why people who come on here with 100,000+ miles on their truck looking to replace the clutch and ask "what's a good brand?" Well your stock clutch just lasted you over 100,000 miles - do you need anymore proof as far as what clutch you should replace it with? In fact many stock clutches will last 150,000 miles or more depending on the type of driving.
Old Dec 5, 2007 | 10:50 PM
Jay351's Avatar
The marlins start at 1200ft-lbs of clamping force (stock is 900) Every single part in the marlin kit is OEM asco/aisin (whatever) the only difference is the springs have been tweaked by the factory for higher clamping force. I couldnt tell the difference in pedal feel when we did mine. It clamped a little harder but I got used to it real quick.
Old Dec 6, 2007 | 01:24 PM
Aaronn's Avatar
I've never had a problem with my napa clutch set..I just rock crawl with it (ohv only)but I've abused it pretty good
Old Dec 6, 2007 | 01:26 PM
bigarms23's Avatar
I would get a centerforce clutch
Old Dec 6, 2007 | 01:49 PM
JamesMk4's Avatar
I put the Marlin 1200 ft. lb. clutch setup on my 94' 22RE and it has been great. It grabs better than the stock unit but you don't feel that increase in the pedal, it feels stock on my truck. Only took 5 days (over a weekend) to get to my door with standard shipping. Overall I'm very happy with the price, performance and the service.
Old Dec 6, 2007 | 02:22 PM
Flash319's Avatar
Stock Toyota all the way.
Old Dec 6, 2007 | 05:01 PM
TC4RNR's Avatar
one more for Marlin 1200#.
here is some first hand info, not he said, she said.
my OEM lasted 145K and the mechanic told me that the clutch disk still had some life on it but the reason for slipping was from the crapped out flywheel which needed some serious re-surfacing. so OEM is good, too.
i called Marlin asking if i "need" a new flywheel, i was told the old one should be fine as along as it's not blue, the mechanic told me the same thing. if money wasnt an issue at that time, i'd go get a new flywheel from Marlin, too.
the pedal is actually lighter with Marlin clutch.
i also had the rear main seal and fuel filter replaced, both OEM parts, no extra labor cost as they are right there while the trans is out.
