My key stopped working
Old Dec 10, 2007 | 05:28 PM
Travisfab's Avatar
So I just went out to hop in my truck and head out and my key wouldn't open the door. It didn't give me any warning or anything. All the sudden, my key wont open the door. The passenger side has never worked, now its the drivers side. I am just really hoping that when I break in, the ignition will still turn.
Old Dec 10, 2007 | 05:34 PM
isaac338's Avatar
i guess with you being in san diego and all, there's no point in recommending lock de-icer..
i couldn't get into the civic for three days until i ponied up for the $2 bottle of lock deicer. stuff is magic!
Old Dec 10, 2007 | 06:46 PM
bigdaddy87547's Avatar
are you able to put the key in the key hole. if so, i would recommend powdered graphite. you can get it at part stores if not the home improvement store. my key would actually go in but would not turn, until the graphite that is!!!!
Old Dec 10, 2007 | 06:48 PM
Travisfab's Avatar
Yeah its a bone chilling 50 degrees at 8 pm here.
Old Dec 10, 2007 | 06:59 PM
90inworks's Avatar
50 wow lucky im like high 20's my pas side wont open i read some were u can go to the stealer ship and they make u a key to open your door its some thing to do with what the original key shape
Old Dec 10, 2007 | 07:21 PM
mtnfreak's Avatar
Probably just worn out. If you've got a spare, try that. If you can have a new key cut using your old key as a template, try that - might make enough of a difference to work. Lastly, try another old Toyota key with a similar cut.
Some information currently being posted here: https://www.yotatech.com/forums/f116/door-locks-131937/.
If you need new locks, just take them all out of the truck and leave them with a local locksmith. It should be no problem to fix them all at once.
Old Dec 11, 2007 | 09:03 AM
Georgiadave's Avatar
My experience was that the new spare key I had solved the problem.
Old Dec 11, 2007 | 09:17 AM
Jay351's Avatar
Any sign of an attempted break in? Thats what did my drivers side in.
Old Dec 11, 2007 | 09:21 AM
Travisfab's Avatar
No sign of a break in, thank god. I am about to break in myself and head down to get a copy made. I hope that works. My uncle owned the truck before me. He locked himself out so many times that he drilled holes in the door locks. Its pretty easy to jimmy a coat hanger down there and pop it open.
Old Dec 11, 2007 | 05:00 PM
Travisfab's Avatar
I jimmy rigged the door open, key works in ignition, new copied key doesn't work in the door and barely in the ignition.
So now I don't have a working key for my doors. I am going to check it out with a locksmith, if that doesn't work It'll be time to install a kill switch.
Old Dec 12, 2007 | 12:32 AM
ovrrdrive's Avatar
I had to switch to my spare a few years ago but it has been working fine ever since...
You might even be able to take toe worn key down and get it copied and the new one might work better. Every copy seems to be just a little different from what I've seen.
Old Dec 12, 2007 | 08:44 AM
cobra6syc's Avatar
Dont make a copy of your worn out key, that is about as usefull as making a key with a file.
Go to the dealership with your ID and registration and have them vin cut the key, that way you will have a brand new original shape key.
Old Dec 12, 2007 | 09:27 AM
Travisfab's Avatar
I already got a copy of the shot out key made, it didn't help, see 2 posts back. I just talked to our local dealer and I am on my way down there, they said they can set me up.
Thanks for the help.
Old Dec 12, 2007 | 09:46 AM
rentedmule's Avatar
I had to have the dealer cut me a new key as well - it stopped working in the ignition. this was 2 years ago and the dealer said they were about to get rid of all the key cutting info for 1993 and older trucks.
Old Dec 12, 2007 | 03:10 PM
Travisfab's Avatar
Alright I have a working key now!!!!! Took my registration into the dealer and the cut me a new key. It ran $15 but it's worth it. My truck is a 94 by the way.
Charecter1
Nov 6, 2023 10:08 AM
icentropy
Jul 11, 2015 07:21 AM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
Jnkml
Jul 6, 2015 01:20 PM
wilbertd
Jul 6, 2015 07:39 AM
