PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 [123] 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267
  1. 3vze Hose Connections
  2. timing belt crank pulley issues
  3. Blowing fuses
  4. 87 4Runner Maintenance.
  5. Power window probloem
  6. v6's with different wiring
  7. o2 sensor?
  8. Un-stake the pinion nut?
  9. What specific tools to pack for 87 4runner
  10. How do I know which tie rod to replace???
  11. EFI fuse keeps poping?
  12. help with all connections including vaccum lines and all the other plug in connectors
  13. Why in the heck would my starter turn over when I put in my clutch?
  14. What did 99blackSE break?
  15. what header is this?
  16. rocker arm adjustment screws.
  17. 3.0 Hot starting issues
  18. M/C...ABS or non ABS
  19. clutch job done, now have slight vibration
  20. sr5 center console
  21. 89 22re loud top end knocking, not a rod bearing
  22. Idle up switch on power steering
  23. 3vze ground valves, now need to know new shim size???
  24. 3vze wont start after timing belt change
  25. ARB style front bumpers for 85-88 pickups?
  26. Aussie Locker #20830 4cyl 8" R.G
  27. Advice on removing grease stains
  28. name this part number
  29. 91 3.0 help!!!!!!!!
  30. is this ticking normal also wire left behind
  31. Power Steering Pump
  32. Need Help ASAP! 22re cuts off under load when you press the brakes
  33. Chopped 4runner Question
  34. Engine Replacement Options
  35. Why does the knock sensor wire divide into two wires
  36. Oil Leaking from Timing Cover Bolts???
  37. Removing stuck torsion bar bolt
  38. code 52. need shielded wire?
  39. Coolant leak side of motor
  40. 1989 Toyote 4x4 pick-up Transmission Question
  41. Where to wire in to reverse signal?
  42. Universal fuel filter and custom lines
  43. 91 Pickup 3vze air leak?
  44. EGR Delete.... Wht to do with FPR
  45. Changed Transmission/T-Case Fluid now it whines
  46. Replacing all brake lines?
  47. Vibrations: Rear diff companion flange?...
  48. Overheats after startup, then runs fine.
  49. deejaysterling's_1987 SR5_4runner Head Gasket Replacement
  50. 22re idle troubleshoot
  51. overheating issue help
  52. Opinions on scenario?
  53. Timing chain and escaping coolant
  54. another exhaust thread 22re/truck
  55. 22re cooling problems
  56. Rear Window Fix worked great!!!
  57. 22re fuel system questions
  58. Windsheild compatibility question
  59. Tailgate wiring
  60. Stock Balljoints Greasable???
  61. brake lines
  62. Overheated, coolant leak on top of the block
  63. headgasket or not?that is the question
  64. Tried to fix fuel gauge and now the Runner won't start...Please help
  65. Moog ball joint no good?
  66. Intermittent no start
  67. 92' 4x4 A340 Transmission Question
  68. timing cover gasket?
  69. UNlifting my 89 Pickup?
  70. Where to buy replacement Interior Trim?..fiberglass the old?
  71. snorkle options and opinions?!?!?!?!?
  72. what does this mean? exhaust puddle
  73. Head flow / plenum flow rates...
  74. 87 22R power upgrades?
  75. 3.0 starter location and removal.....
  76. Transfer shifter install question
  77. Turbos, power chips, exhaust?
  78. Weber carbs and vacuum leaks plauge me!
  79. Clutch kits: Wading through the choices
  80. Explorer procomp lift question
  81. DIY Video: 1994 4runner Complete Front Brake w/ New Rotors & Wheel Bearings
  82. Cold air intake vacuum line
  83. Picked up an 86 truck with an 83 diesel motor in it.
  84. head light bulb help
  85. Junkyard 4.88 IFS front 3rd member checkup help
  86. 22re powersurge issue
  87. 3VZE Exhaust\Torque Curve Adjustment
  88. AFM to MAF conversion
  89. 89-95 aftermarket bumper on my 88 pickup??
  90. 1st Generation 4runner Fuel Sending Unit ?
  91. power loss
  92. Repainted AISIN manual hubs ! What do u guys think ?
  93. Rear window switch wiring question
  94. Doing some preventative maintenance, fuel pump replacement..Mount plate PN?
  95. stripped distributor bolt
  96. drifting issue after seized caliper
  97. Cab Corners For 89-95 pickup
  98. 1994 toyota dlx low idle misfire
  99. Toy Connection Rebuilt Engine
  100. running on 3 cylinders
  101. 92 Tailgate Lock
  102. 86 Fuel Pump Bracket
  103. 4runner Half door Windows!!
  104. Water temp sensors.... 22re
  105. 22re transmission/bellhousing question
  106. 22re running rich running out of ideas.....????
  107. Had an accident. Does it need an alignment, or worse...
  108. 94 Pickup 4x4 3vze Alternator Issue
  109. sticking intake valve
  110. Fixed Window, now top problem
  111. a/f ratios... too rich?
  112. AUTO Transmission popping out of gear
  113. What is this dyno chart saying is wrong? 22RET
  114. 63 chevy swap kit vendor selection
  115. 1988 toyota pickup 22re
  116. stock tire size
  117. vaccum lines and 4x4
  118. 3.0l ticking gone!
  119. Loud rattle when I push the clutch (22RE)
  120. 87' 4runner interior lights not working. Any ideas?
  121. clutch release cylinder
  122. brand new exedy and brand new flywheel causing chatter!!
  123. Sunroof Seal...
  124. Help....High NOx at 15 MPH on smog (Calif)
  125. hack job wiring, can you ID these wires?
  126. 92 Yota Pickup has little power
  127. install studs without removing the head?
  128. R12 AC Recharge kit
  129. 98 3.4 trans questions
  130. JAN94 2nd gen Runner ad in R&T
  131. Short Shifter for 3vze
  132. Ready for off-roading...maybe
  133. Fuel (prime)
  134. Oil in ac vents
  135. Front end wont hold allignment
  136. Removed my Sway Bar Today
  137. Broken stud on my downey headers.
  138. oil pan differences?
  139. 2nd post on 94 pickup same low rpm missing problem 3vze
  140. 93 4runner bad gas mileage
  141. Strange Tach issue.
  142. "big 3" question...
  143. 4runner chop enclosing HELP!
  144. 1990 runner.tranny problems :(.3.0v6
  145. pls help egr delete in progress
  146. think it will leak/ Time chain cover
  147. Where to get rear quick disconnects?
  148. trouble shifting when cold
  149. Replaced some parts and still can't get idle right.
  150. Front sway bar removal.
  151. '87 22r emissions/evap removal help
  152. Wierd Problem with cooling temp problem.
  153. A/C Not cooling though the clutch is engaged.
  154. Loud Tapping
  155. Machine shop advice re: 3.0 head gasket replacement
  156. Weber 32/36 install question....
  157. 87 22r headgasket????
  158. oily coolant leak 3.0 4Runner
  159. Back again--this time with an 88 4runner
  160. Are head to block guide dowel pins sold?
  161. 1988 22re idling problems
  162. Truck wont hold a charge anymore
  163. Spare Tire fitment question
  164. 3.oh no ist kaput
  165. Jerky on decelleration
  166. Retighten head bolts?
  167. 4runner spare tire cover
  168. different size tires front and back..
  169. poor/very low idle after oil change to 5w30
  170. 22re misses
  171. Vacuum hose problems what is this??
  172. 95 3vz-e running rich
  173. 22re dead miss
  174. 89 4Runner 22RE acceleration issues
  175. Help! Winters coming and I have no heat.
  176. Nasty vibration 3rd through 5th gear
  177. EMS Offroad Tire Carrier Kits any good?
  178. 3.0 PCV Valve Relocation (easy/quick change)
  179. Radiatorbarn.com 3 row all metal radiator
  180. 94 Toyota ecm pinout
  181. Kick down cable part number needed a43d
  182. Black sooty tailpipe.
  183. Injector noise getting the best of me.../:?
  184. Truck only runs at 20-25 BTDC!
  185. Oil leak after new timing set???
  186. Emergency brake adjustment?
  187. Common Idle Surge / Trouble setting ignition timing problem
  188. I ruined a fusible-link. I could kick myself...
  189. Thoughts on TG's GM to toyota alt bracket?
  190. New to me: 87' 4Runner 4x4 SR5 22RE-5spd
  191. Bought my first Toyota (1987 Xtra-Cab 4X4 22R) and have a few carb. questions
  192. Is there a way to make dash lights brighter ?
  193. WAAAHHH! Rustoleum Roll-on
  194. 4runner speedometer/odometer erratic
  195. Trans Dipstick tube mounting NEED PIC!
  196. A/T oil temp light flicker?
  197. wierd electrical problem with 87 4runner
  198. 98 Tacoma grill onto 90 4runner is it somewhat easy??
  199. 88 22re Issues
  200. 91 4runner vs. 86 turbo? trade??
  201. P/S Box rebuild
  202. Help, please! 22RE Idle problem.
  203. Start up knocking on a 93 4cyl
  204. Which wire is ground?
  205. '92 4Runner 3vze stumbles/hesitiates
  206. 87' 22RE 4x4 A/C VSV vacumm line question
  207. 22re MAF sensor delete is it possible/
  208. RIP Mightymouse. My truck caught fire! time for a new one.
  209. 1994 4-runner ADD does not work where do i start
  210. Electric fan mod on 22re need input?
  211. 86 4Runner no gauge backlight
  212. balljoint's and Idler arm.. what brand???
  213. Has any one had experience with XTR clutchs off of ebay?
  214. Update on motor swap clutch ect
  215. Valve lash adjustment
  216. wiring harness
  217. teeth on flywheel?
  218. wrecked toyota/rebuilding help...
  219. Stuck on timing chain job!?!?
  220. Manual hubs unlocked, CV axles spin above 15mph? help please
  221. 3.0 Valve Stem Seals Question
  222. Rod Knocking
  223. Cv boot reinstall question
  224. Someone smashed my bumper last night
  225. Rotella T6
  226. Smoke from dash, No power windows
  227. Crank bolt 2, me 0 :D
  228. e-locker questions
  229. check engine light flashing when driving NO CODES!!
  230. Uh Oh... Pushed Clutch Pedal and heard a snap :/
  231. 88 4runner 3vze misfire
  232. 1994 4runner front transfer case leak
  233. 88' 4runner fuel pump compatibility options...
  234. 94 4runner e-brake bracket help
  235. No Spark - 91 Runner 3VZE
  236. SDORI IFS brace
  237. Need opinion on front end accident.
  238. need help finding ignition "on" hot wire
  239. Why are 3vze cylinders shaped odd?
  240. Engine temp sensor question
  241. Which drive train do I have???
  242. how to check code 3vze.. sorry!
  243. 1993 toyota p/u seats
  244. Procomp AAL w/ Stock U-Bolts???
  245. '90 Pickup DLX Speedo Problems.. Possible to convert to electric?
  246. Changed the CSI switch,no improvement?
  247. w56 tranny/transmission seals
  248. Transfercase chain question...
  249. truck wont start!! help!
  250. My '95 4Runner
