22re MAF sensor delete is it possible/
Old Oct 17, 2010 | 01:05 PM
92Yotaa's Avatar
i am wanting to run my 22re with a aftermarket airfilter straight to the manifold with out the mass air flow sensor does anyone know if its possible
Old Oct 17, 2010 | 01:07 PM
xxxtreme22r's Avatar
one word, NO
the MAF is there to tell the engine how much air it's getting into it so it knows how much fuel to put in, if there is no MAF how will the engine know how much fuel to put in. ???
sounds like you got to talking to one of your ricer buddies and his CAI in a car that has a MAP and not a MAF.
Old Oct 17, 2010 | 01:35 PM
92Yotaa's Avatar
no its just the way that it looks i have a cheap air intake thats runs all the way to the otherside if the truck it looks bad and i just wanted to see if it could be out straight on to the intake
Old Oct 17, 2010 | 01:36 PM
IngSoc's Avatar
Tottally can get rid of it.... Go carburated
Old Oct 17, 2010 | 01:42 PM
Randyman...'s Avatar
What about the Supra AFM swap? Might help your cause?
Old Oct 17, 2010 | 01:45 PM
myyota's Avatar
First of all our trucks don`t have a MAF, they have a mechanical air flow meter (AFM), there is a huge difference between the two. If you don`t like the factory set up with the intake running across the radiator, then do a battery/ intake swap. Do a search, many here have done this and you can also upgrade to a larger AFM that will give you a small gain in power. If you keep the stock AFM you can get an adapter to put a cone filter on it so you can remove the factory air box.
Old Oct 17, 2010 | 01:52 PM
BigBluePile's Avatar
Geezus. Do some searching yo.
No you can't delete the AIR FLOW METER. That's like removing the gas tank.
You want to clean up the engine bay? Do the battery/intake swap. Put some spectra gear on it. Oh and don't forget to hang a caribener off your rear bumper....
Old Oct 17, 2010 | 01:57 PM
I'm with him ^^^^^
myyota's Avatar
^^ lol ^^ At Big Blue Pile.
Old Oct 17, 2010 | 05:31 PM
874runnersr5's Avatar
or standalone?
http://www.toyotacatalog.net/M1WebGe...E-391C3F70E0C5
Old Oct 17, 2010 | 05:45 PM
irab88's Avatar
bat/intake swap
supra afm
smthwsn357
May 1, 2024 07:28 AM
Jun 1, 2021 01:51 PM
montanatruck
Feb 26, 2017 07:07 AM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
bryan34w
Jul 6, 2015 05:53 PM
