Which wire is ground?
Old Oct 17, 2010 | 04:13 PM
mldave's Avatar
cold start switch(black) on left.Which wire is ground?
Old Oct 17, 2010 | 04:26 PM
xxxtreme22r's Avatar
good reason to have a multimeter.
$36.99 http://www.harborfreight.com/3-1-2-h...kit-95670.html
$3.49 http://www.harborfreight.com/7-funct...ter-98025.html
Old Oct 17, 2010 | 04:28 PM
874runnersr5's Avatar
black with white line
Old Oct 17, 2010 | 04:40 PM
mldave's Avatar
Thanks man,and the green temp sensor on the right in photo does not appear to have a copper washer,is it supposed to?
Old Oct 17, 2010 | 04:41 PM
lemme double check quickly, i got the fsm open right now.
that sensor is your coolant temp sensor i believe.
Old Oct 17, 2010 | 04:54 PM
mldave's Avatar
Yes,but does it need a copper washer?
Old Oct 17, 2010 | 04:58 PM
yeap it should have one on.
Old Oct 17, 2010 | 05:15 PM
mldave's Avatar
Thanks,thought it might..I see no leaks..can this in any way add to the cold start problem by not having the copper washer?
Old Oct 17, 2010 | 05:22 PM
i doubt it, whats the problem?
Old Oct 17, 2010 | 05:44 PM
mldave's Avatar
Have had to crank 3-6 times till it starts in the morning after sitting all night,all other times it starts and runs great.This on my 86 truck 4x4 2.4 EFI.My friend changed the cold start injector time switch to the original OEM updated part # 89462-20050.One in there was for a corolla or some such.Anyway it's still hard starting after the switch change,though mostly starts on three cranks now in the morning.Could it be a plugged/or bad cold start injector?We may just bypass the CSI time switch when my friend has time,but that could be three weeks or more,and perhaps that wouldn't fix it either.
okamikai
Apr 30, 2018 10:19 PM
sanctfy
All Other Toyota Swaps
Sep 15, 2015 02:52 PM
Esibnitsud
Jul 30, 2015 08:19 PM
TDonkey
Jul 26, 2015 10:14 AM
v_man
Jul 23, 2015 04:01 PM
