poor/very low idle after oil change to 5w30
Old 10-19-2010, 01:34 PM
Ruined Adventures's Avatar
I usually use Royal Purple 10w-30 in my 87 4runner (22RE 5spd). About a month ago I spaced out and used 5w-30 Royal Purple when I changed the oil. Afterwards I noticed idle issues. After startup, the engine would stall unless I'd give it gas and keep the idle up. I'd basically have to rev it up a hair between stops just to keep it running. After about 10 minutes it'd be warmed up enough to idle on it's own and not need the extra gas. I lived with this since I figured it was because of the 5w-30.
I finally got tired of these shenanigans and changed the oil last week with 10w-30, hoping the problem would go away. Well, now it hasn't and I'm getting irritated.
What steps should I go thru to figure out what's causing this? Any help is appreciated.
Old 10-19-2010, 01:38 PM
xxxtreme22r's Avatar
think back on your last oil change and look to see if you knocked any wires loose while doing the oil change process.
things like did you pull your air filter to check it, where did you lay your tools in the engine bay, did you drop anything and have to get any of the tools inside the engine bay etc etc not just the normal stick my hands in there and remove the oil filter kinda thing. unless of course that's all you did.
Old 10-19-2010, 01:52 PM
tim a.'s Avatar
I dont understand how changing oil viscosity would have any effect on idle quality.There is no oil thickness sensor to tell the ecm the difference.Sounds like you have a vac leak.
Old 10-19-2010, 02:57 PM
I may be a noob, but cut me a little slack!
Haha, good advice actually. I didn't leave or drop any tools, but I did notice something while checking the air filter. Thanks for the simple, yet helpful tip!
I didn't understand how that would affect it either but after doing some searching it seems several people have experienced idle issues after changing oil viscosity. I don't understand it, but that's just what i figured it was originally...but I think you're on to something with the vac leak
Old 10-19-2010, 02:59 PM
snobdds's Avatar
You changing your oil to a different weight did not cause your idle problems. Something else is going on there...more info is needed!
Old 10-19-2010, 03:11 PM
Looks like I tweaked my intake hose while changing the filter in the airbox.
Where is the best place to find a replacement? I'd rather not overpay at the stealership...
*edit: nevermind, surprisingly Autozone carries it...this should fix my problem right? makes sense to me.
Attached Thumbnails poor/very low idle after oil change to 5w30-tiny-tear-hose.jpg   poor/very low idle after oil change to 5w30-big-tear-hose.jpg
Old 10-19-2010, 03:13 PM
I'd be willing to bet that that big hole is what is causing you problem because the AFM is not measuring the right amount of air into the motor.
Old 10-19-2010, 04:26 PM
TNRabbit's Avatar
I was going to say make sure your oil cap is sealing, but YEP, that would do it! LOL~
Old 10-19-2010, 04:31 PM
ut oh not this again. You mean the motor runs weird with the oil cap removed?
Old 10-19-2010, 04:44 PM
Oh boy, did I open up a can of worms?...
The part's not available for now so I had to order it. Luckily I found some leftover multi-purpose, reinforced, polyethylene pressure sensitive tape with a soft and flexible shell and pressure sensitive adhesive in the toolbox...and what do you know, the idle is great again. Thank god for duct tape!
Old 10-19-2010, 04:46 PM
Old 10-19-2010, 05:58 PM
myyota's Avatar
Look on ebay, you can usually find new ones for sale there.
Charecter1
11-06-2023 10:08 AM
bigjstang
08-25-2021 12:41 AM
icentropy
09-16-2020 02:47 PM
MTLroadierunner
07-06-2015 12:17 PM
HRDC0R19
07-05-2015 06:43 PM
Quick Reply: poor/very low idle after oil change to 5w30
