Rear window switch wiring question
Old Oct 24, 2010 | 10:44 AM
isaac338's Avatar
My rear window won't work with the key switch in the tailgate, it'll work fine with the dash switch though. Does anyone have an accurate wiring diagram for this? The FSM only shows 3 wires at the switch but mine has 5.
Cheers!
Old Oct 24, 2010 | 10:53 PM
yotaconvert's Avatar
Hey man i think it is your rear window power control module i had the same problem but mine would not work inside and worked outside
Old Oct 27, 2010 | 05:42 PM
redcobragt's Avatar
Can you tell me where this module is located at, and where did you find one. Thanks
Old Oct 29, 2010 | 10:35 PM
Blue 89 Runner's Avatar
Same here
Old Oct 29, 2010 | 11:08 PM
99blackSE's Avatar
The rear gate window control box is at the back behind the interior panel on the driver's side.
Old Oct 29, 2010 | 11:41 PM
Datsayota's Avatar
Here is a diagram for that window, good luck.
Old Oct 30, 2010 | 09:33 PM
brad11140's Avatar
Just replaced my rear window relay module. As they said it is located behind the interior panel. If you put your tailgate down and pulll the panel off on the drivers side you can feel around in there. Its located back aways toward the tail light area. There are 2 bolts that hold it on so you will need to pull the trim back to get to them.
Ive got money on this module for your problem as well. When you turn your key can you hear the relay clicking? They run about $30-$50 on ebay. Ive seen one on there for awhile. Make sure you pull out your and get the numbers off it because there are a few. I found mine at the junkyard for $8. Fixed all of the problems.
Old Oct 30, 2010 | 10:26 PM
Mine worked with a smashed tailgate, after I replaced it, nothing, not with switch or key. Then put in old stuff and still nothing. Everything else works back there, wiper, washer, defroster... guess I'll try another module ?
Old Oct 31, 2010 | 03:51 AM
wyoming9's Avatar
Red face
Did you pull your switch from the old hatch??
Did you check with multimeter to see if the switch on the replacement hatch is any good??
If you swapped the key switch in the hatch maybe the switch contacts were just dirty enough not to work .
Real likely if the lock cylinder had been pulled out for any length of time.
Old Oct 31, 2010 | 10:01 AM
01d's kool's Avatar
2 of the 5 wires at the connector about 8" from the switch are for the plate lights (white w/black stripe and green w/ blue stripe) the solid blue one is a common to the keyswitch and the blue/white and blue/black wires go to the module behind the driver's seat to lower and raise the window. Check for continuity through the switch between the blue and either the blue/white or blue/black depending on the position of the key. If the switch is good, check for continuity between the connector near the switch and the connector near the left tailight. If good then it is probably the module. I got lucky and found one from an '89 runner for $5 from the local yard (real lucky!)
Old Oct 31, 2010 | 10:58 AM
Yes, old switch from original hatch, know it was working. Think I'll hunt around for that module and see what happens. So, module is in the LR corner, correct ? See someone said something behind drivers seat.
Old Oct 31, 2010 | 01:22 PM
Just searched high and low in the back corner and can not find any module . Am I blind ? Only things I see back there are the jack, washer bottle, and the plug that comes from the tailgate into the harness headed back up front .
Old Oct 31, 2010 | 05:23 PM
01d's kool's Avatar
you gotta pull the panel behind the driver's seat and you will see it bolted to the support. it's a rectangular box with 13 wires going to it. right next to it will be a round relay for the rear window defroster (if so equipped)
Old Oct 31, 2010 | 05:46 PM
OK, was under the impression it was in the LR corner by the taillights based on a previous post. Have to move a bunch'o'crap outta the way to get to it.... have a mobile wash and detail set up in the back of the runner ! Thanks !!
Old Jan 9, 2011 | 10:24 AM
chosenchange's Avatar
any one know how to wire the inside switch to be always hot? All I would really have to do is run wires off the battery to the switch correct and use the wires That I have ran from the window direct. Least thats what I think its kinda hill billie wiring but I have no choice the truck has an electrical nightmare gonna have to rewire the whole truck soon.
Old Jan 9, 2011 | 11:02 PM
Decided to look into mine a bit more today . I can hear that module click when I use the key or hit the switch, but window no worky !! Bad module or .....
Old Jan 10, 2011 | 02:53 PM
motocaveman's Avatar
http://www.4crawler.com/4x4/CheapTri...arWindow.shtml
Old Jan 20, 2011 | 10:01 PM
Thumbs up
Module arrived in mail today, put it in and the rear window now works as designed !!! No more red top Optima on the front floorboard to open the rear window !!!!
Old Jan 21, 2011 | 07:21 AM
cracker_1's Avatar
My 87 does the exact same thing. Rear window works by the interior switch, but not with the key. So, I am going to pull the relay out and see if I can find another one....
Old Jan 21, 2011 | 07:37 AM
4Crawler's Avatar
How I modified mine:
- http://www.4crawler.com/4x4/CheapTri...ow.shtml#Relay
