Oil in ac vents
Old Oct 21, 2010 | 03:42 PM
thisgsx's Avatar
Oil in ac vents
I have oil in the ac vents, and a pretty strong oil smell inside the vehicle while driving. Could this be caused by a rear main seal leak? Valve cover gasket?
Old Oct 21, 2010 | 04:43 PM
TNRabbit's Avatar
No. That is bizarre. The ONLY reason I can think of to have oil in the A/C vents is if your A/C condenser has a leak, but then your A/C wouldn't be working.
Old Oct 21, 2010 | 04:52 PM
swampfox's Avatar
Do you have a oil leak that lets oil on to the exhaust manifold? It might be drawing in smoke or fumes somewhere.
Old Oct 21, 2010 | 06:04 PM
just call me smithy's Avatar
x2 on what swampfox said i had the same problem.
Old Oct 21, 2010 | 06:15 PM
mikes451's Avatar
I think its your evaporator not the condenser. Evaporator is under dash, condenser is in front of radiator.
Old Oct 21, 2010 | 07:06 PM
thisgsx's Avatar
The only leak I am aware of is the rear main seal and the valve cover gasket. The valve cover gasket was just replaced a month or two ago. The darn thing is leaking again. As far as the evaporator goes, I pretty much stripped the whole interior to run power, rca, and speaker wires. I didn't notice anything odd, visually nor anything that smelled like oil from under there. The AC vents are covered with a film of oil. The odor gets worse the further I drive or the harder the car has to work. The timing belt, front cam seals, crankshaft seals were all replaced when the valve cover gasket was done. All the upper plenum gaskets and throttle body gaskets were also replaced.
Old Oct 21, 2010 | 07:09 PM
thisgsx's Avatar
The only place that could be doing that is the valve cover. I don't know of any other place where oil could be dripping down onto the exhaust manifold.
Old Oct 21, 2010 | 07:10 PM
thisgsx's Avatar
what was the cause of it? did you get it fixed?
Old Oct 21, 2010 | 07:25 PM
valve cover gasket, ya but went with the gasket maker by toyota instead of the rubber one. some people also use it on oil pans, i forget the name some one might be able to name it for me
Old Oct 21, 2010 | 07:34 PM
ok i found the name toyota fipg sealant that's the stuff you wana use
Old Oct 21, 2010 | 07:57 PM
thisgsx's Avatar
OK, so you didn't use the rubber gasket?
Old Oct 22, 2010 | 12:41 AM
TNRabbit's Avatar
Originally Posted by mikes451
I think its your evaporator not the conden'ser. Evaporator is under dash, condenser is in front of radiator.
Sorry; you're right. Had a senior moment there~
Old Oct 22, 2010 | 01:04 AM
DaddyRunner's Avatar
I'm not sure about oil in the vents but I currently have a very small leak in the back of my passenger side valve cover. Unfortunately that is right above the damn crossover pipe and I do get a pretty strong burnt oil smell in the cab sometimes.
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
dumpster84
Apr 30, 2016 06:03 AM
TJWilly
Jul 31, 2015 02:05 PM
calderp
Jul 27, 2015 09:58 AM
britishdudes2dr
Jul 25, 2015 06:47 AM
