trouble shifting when cold
Old Oct 20, 2010 | 05:22 PM
yotarover's Avatar
i recently changed out the transmission fluid it's a 89 dlx auto didn't have any issues before. figured i'd throw in a bottle of lucus trans oil every since then every mourning it takes forever for it to shift from 1st to 2nd. i can barely even hit 35mph.
https://www.yotatech.com/forums/f116...crewed-211862/ helps some what
any ideas or anybody else had this problem
Old Oct 20, 2010 | 05:37 PM
wii_tarded's Avatar
I had this problem last year with my manual. A local shop tore it down for an inspection (never going there again) and reassured me that the trans was fine and they were going to put a "nice, heavy weight" oil in to help protect it. The oil was so thick that it kept me from shifting until I was able to warm it up through friction of the gears turning. Drained it and put in spec.ed weight gear oil and never had a problem again.
Old Oct 20, 2010 | 06:47 PM
survivorman97's Avatar
My manual had the same problem. I was running mobile 1 75-w90. It was too think, it was fine in the summer but when it got cold it got much thicker and was hard to shift. I put in BG synchro-shift II 75-w80 and this problem is practically non-existent now. Maybe the stuff you put into yours is too thick too.
Old Oct 21, 2010 | 12:14 AM
TNRabbit's Avatar
Can you use Lucas in an auto tranny??
Old Oct 21, 2010 | 12:21 AM
myyota's Avatar
I would drain the trans fluid and refill it with regular ATF and see if the problem goes away.
Old Oct 21, 2010 | 11:40 AM
yotarover's Avatar
that's what i used . right before it started to get cooler it started the slow shifting so im going to just drain it out (save it) and put more back in . don't get me wrong it shifts perfect once it warms up nice and smooth you can't even feel it i'll add some back just less this time
Jayboy74
10
Dec 21, 2021 08:27 AM
mskalmus
May 28, 2017 07:51 AM
Marsheen
Feb 17, 2016 12:29 PM
skoob
Oct 15, 2015 03:23 PM
markf1
Sep 3, 2015 01:23 AM
