running on 3 cylinders
Old Oct 23, 2010 | 05:42 PM
Rusted Rooster's Avatar
Hi everyone, did a head gasket, timing chain, oil pump,water pump, replacement, all parts from enginebldr,
1987 22re. Got her started today, problem is, noticed she was missing.
losend distrubtor and advanced it back and forth, no change,
Started pulling plug wires to see which one was maybe affected.
found when i pull #1 wire it runs the same as it was hooked up... so for some reason #1 is missing?,,, any help here will be great,, did try differnt spark plug,, plug wire,,, pulled dist and checked t.d.c. 3 times.. HELP!
Thanks.
Old Oct 23, 2010 | 05:48 PM
myyota's Avatar
You need to check the compression on all cylinders, let us know what you find.
Old Oct 23, 2010 | 10:45 PM
the_supernerd's Avatar
Maybe you have a valve on the #1 cylinder too tight after doing the headgasket?
Old Oct 24, 2010 | 03:23 AM
Thanks for feedback! was thinking, maybe #1 fuel injector? I am getting nice spark from #1 plug wire, Funny thing when i was taking her apart, i had marked each injector wire 1thu4, Had to take the whole intake apart for a good clean and check,
when putting back together #1 injector wire had no mark? there is another p;ug that looks like injector plug i had put a #1 on? sorry this what i was thinking in shower last night. hope it makes sence,,well back to the garage,,,,thank you so much.I will try all your posted ideas.
Old Oct 24, 2010 | 11:15 AM
If there is another connector nearby that will fit the fuel injector, then that is a good possibility with an easy fix. If that does not work, check the fuel injector plug with a node light and check the compression on the #1 cylinder.
Old Oct 24, 2010 | 12:01 PM
dark_fairytales's Avatar
i have come across this issue many times of YT. and even my self. I would suspect the connection to the injector.
Old Oct 24, 2010 | 12:03 PM
Crimson Yota's Avatar
Try removing the distributor cap and checking inside for any damage.
My Runner was running only on 3/6 cylinders and I found a piece in my distributor was messed up a couple days ago (got it back from the mechanics like that)
New distributor fixed it right up.
Edit: Sorry I thought yours was a 3.0..
Last edited by Crimson Yota; Oct 24, 2010 at 12:04 PM. Reason: Didn't read carefully enough
Old Oct 24, 2010 | 03:48 PM
Hey guys got it figured it out.. was a bad injector plug on #1 injector,, must have cracked it during cleaning or somthing,,
Did the old screwdriver test to the injector, ear to screwdriver. found #1 was not clicking in my ear. BINGO!! now i just gotta retap disbrutor bolt hole,, little stressed about how to do it,, just want to say THANKS for all the help.
Old Feb 5, 2011 | 06:22 PM
Retapped it to 9/16. only u.s.a. bolt in engine. bolt prob made in china
Sleaker
Aug 26, 2020 06:03 AM
jasonty
41
Dec 23, 2018 01:00 PM
Doug4320
Mar 24, 2018 10:11 PM
Sep 4, 2015 09:27 AM
cars-guy
Jul 11, 2015 07:51 PM
