88 22re Issues
Old Oct 17, 2010 | 08:45 PM
02gmc5.3's Avatar
88 22re Issues
I bought somebody else's project that needed an engine and have a timing issue after the swap. It sounds the same(tries to start) regardless if the ecm is plugged up or not and the check engine light comes on when the switch is off(with the ecm plugged up).
Old Oct 17, 2010 | 10:22 PM
muddpigg's Avatar
check the ground that originates from the ecm wiring harnes and attaches to the rear half of the lower/upper intake junction. its well hidden.
Old Oct 18, 2010 | 04:54 AM
02gmc5.3's Avatar
Originally Posted by razed
need more info.
cel is on with the key off?
what sort of swap?
the ignitor will generate spark while cranking even if the ecu may be failing- that's how it works. once the engine is running the ecu takes over timing control.
so you're not giving enough 411 to troble shoot.
22re to 22re swap, I'm not familiar with toyotas at all. Base timing is dead on and it's getting fuel. If the ground wire your talking about has a few wires coming from it and falls close to the starter then I actually hooked that up to the positive side and that would explain everything.
Old Nov 4, 2010 | 11:57 AM
83hightoy's Avatar
is the engine you swapped in an 88 also or did u swap the injectors and stuff
Old Nov 4, 2010 | 03:18 PM
02gmc5.3's Avatar
It was the ground wire, it's fixed now.
Old Nov 4, 2010 | 04:56 PM
muddpigg's Avatar
Glad to hear, I'm pateintly awaiting my head back from builder:-)
bigjstang
Jun 2, 2025 03:56 PM
MO transplant
Apr 23, 2023 11:58 AM
mskalmus
May 28, 2017 07:51 AM
montanatruck
Feb 26, 2017 07:07 AM
PlayAwhile
Jul 20, 2015 11:36 AM
