Wierd Problem with cooling temp problem.
Old Oct 20, 2010 | 01:03 PM
geeq's Avatar
Items I changed with new:
Radiator, radiator cap, water pump, all hoses, Thermostat, Engine coolant temp sensor, and coolant temp gauge sensor.
My problem is when driving its great. Needle stays a 1/3 mark and doesnt really move much no matter what. AC Running or Heater running.
But when I stop to go into the store and come out 10 minutes later and start engine......The gauge is just below the RED. Then I start driving and goes back to 1/3
Why is it heating up when not running? I couldn't find any info on this particular problem.
Old Oct 20, 2010 | 01:05 PM
OrRunner's Avatar
thermostat sticking maybe? try swapping another in...
as far as why it heats when not running, this is called heat soak, as the engine runs coolant is passed through the motor to cool it, when the motor shuts off, not coolant flow to cool down the motor so what ever heat is created by driving does not get cooled quickly
Old Oct 20, 2010 | 01:07 PM
geeq's Avatar
Oh, I did thermostat too. I forgot to put that.
Old Oct 20, 2010 | 01:09 PM
geeq's Avatar
I didnt replace it at first and had the same problem. So I tried a new one but problem still the same.
Old Oct 20, 2010 | 01:17 PM
geeq's Avatar
I accidentally broke the sensor for the Engine coolant temp while putting in a fuel filter. Drove truck maybe 5 miles with check engine light on and has hesitation and back fire.
Checked the code and it was # 22
Then I saw I broke the plastic end of sensor. So I replaced it and the coolant temp gauge sensor plus everything else.
The gauge was jumping around a bit still from 1/3 to 2/3 when driving. So I changed the thermostat. That fixed the temp to 1/3 on the gauge and ran perfect.
But still heats up when turned off. Can't figure out what else is wrong. Can the brand new sensor be bad?
But I smell coolant when I restart the vehicle like it is really hot like gauge says.
Old Oct 20, 2010 | 07:15 PM
Kelly G's Avatar
Mine does this same exact thing maybe someone can help.
Old Oct 21, 2010 | 12:15 AM
TNRabbit's Avatar
Your fan clutch is bad.
Old Oct 24, 2010 | 04:31 AM
pruney81's Avatar
a new fan clutch wouldn't hurt.
Old Oct 24, 2010 | 05:07 AM
4Crawler's Avatar
X2 on the fan clutch:
- http://www.barneymc.com/toy_root/techneek/fan_clch.htm
- http://www.4crawler.com/4x4/Docs/FanClutch.pdf
It is the fan clutch that moves air through the radiator when you are not moving.
Old Oct 24, 2010 | 07:13 AM
geeq's Avatar
Originally Posted by razed
does it ping? maybe double check your timing things may be okay with the coolant circ, but turn it off and the heatsoak in thehead can cause the coolant and intake to soak up some of the heat
how soon after starting does the gauge go to 1/3? on mine 22re it takes about 10-15 minutes idling or within about 5 miles driving
After I start engine when heated up I take about 5 miles or less and the temps goes back down to 1/3
I can't imagine the engine heating up and cooling down the coolant that many degrees in minutes.
I thought it might be the sensor........Since other problems would come up if it was actually overheating.
Old Oct 24, 2010 | 07:14 AM
mightymouse's Avatar
x3 fan clutch
Old Oct 24, 2010 | 07:26 AM
geeq's Avatar
Originally Posted by mightymouse
x3 fan clutch
When the truck is off why would it be the fan clutch?
The temps are great when driving. Once turned off and left for 10 minutes then restarted the temp will be high.
Old Oct 24, 2010 | 07:43 AM
the fan really isn't working well but air is still moving through the radiator right so it cools your engine while your driving. When you start your truck up after you get back and the temp gauge is high you should hear the fan engage and roar while driving. Tell you what if you wanna be sure about it go drive in traffic or on the highway and let the engine warm up. park it and pop the hood. reach down and see if the fan has resistance meaning you can't or can easily spin it. If it free spins easily you need a fan clutch. if not and it doesn't then you have other problems. Or if you run it to operating temp and drive around and just sit and let the truck idle not turning it off you should be able to hear the fan. Trust me there is a difference i noticed when i replaced mine.
Old Oct 24, 2010 | 12:19 PM
geeq's Avatar
Will try later today.
the1998sr5
15
Jul 14, 2020 08:35 PM
gary4runner
Sep 24, 2015 12:53 AM
Poncho0206
Jul 10, 2015 06:21 PM
Avenged
Jul 9, 2015 07:55 AM
bryan34w
Jul 6, 2015 05:53 PM
