Un-stake the pinion nut?
Old Oct 29, 2010 | 11:27 AM
broncbob's Avatar
what is the best method to un-stake the pinion nut on the rear end?? I have to do my pinion seal!
Old Oct 29, 2010 | 11:36 AM
ZUK's Avatar
ZUK
not needed. The staking action only requires a few extra ft/lb to over-come. I have never un-staked a nut yet. ZUK
Old Oct 29, 2010 | 11:42 AM
broncbob's Avatar
ZUK, any issues with keeping the nut tight once the seal is replaced and nut re-installed? I should stake it again, right? Maybe some loctite for things??
Old Oct 29, 2010 | 12:18 PM
waskillywabbit's Avatar
Considered a non-reusable part and for what they cost I always just get a new one.
Stake it with punch and hammer.
:wabbit2:
Old Oct 29, 2010 | 12:19 PM
blake.nemitz's Avatar
i always tack mine a little to keep from backing off and if you need to a quick turn of a breaker bar will break it free
Old Oct 29, 2010 | 12:40 PM
InternetRoadkill's Avatar
Can you tap the seal out without damaging it? I need to adjust the preload on my pinion.
Old Oct 29, 2010 | 12:47 PM
you dont need to take the seal out just tighten the nut for more preload or loosen a hair and tap end of pinion with hammer to loosen preload. and as far as crushsleeves go i know ill hear it for this but after proper preload has been fouind and broke in there is no further use for the crush sleeve as long as the nut isnt going to move both my diifs dont have tham as well as my old jeep, dont need them.
Old Oct 29, 2010 | 12:48 PM
I doubt it.
:wabbit2:
Old Oct 29, 2010 | 12:51 PM
Don't use crush sleeves. I got shims and a solid spacer.
kawazx636
Oct 6, 2021 03:03 PM
voiddweller
Oct 2, 2015 07:47 AM
hiluxinargentina
Sep 30, 2015 11:12 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
Odin
Sep 26, 2015 06:56 PM
