22re dead miss
Old Oct 19, 2010 | 09:54 AM
cman1's Avatar
22re dead miss
First off,you guys are awesome!! great info,very well put together forum.this is my first post...i just picked up a 86 pickup,22re,5spd,4x4,234k.it has been sitting for 3yrs.owner put a battery in it and fired right up.awesome,only has a dead missheres what ive done so far.removed old gas,put in fresh w/seafoam.ran for a few minutes,same.compression test#1/150 #2/151 #3/150 #4/152.new plugs,wires,cap,rotor...same.has good white spark to all 4.started pulling wires while running,#2 cyl is the culprit! now,at this point im looking at re-building fuel injectors,yes? is there anything im overlooking as im not real up on 22re's and theyre quirks.my first one,its little..how bad could it be,hehe
Old Oct 19, 2010 | 09:59 AM
xxxtreme22r's Avatar
you sure that #2 plug is actually firing? pull that plug out attach it to the plug wire and ground the tip to something and see if it's actually firing. Maybe you just have a bad spark plug. or the wire is bad.
Old Oct 19, 2010 | 10:26 AM
cman1's Avatar
actually swapped plugs,same.previous owner gave me the old plugs that were marked by cylinder and #2 whas really white ,ashy lookin,lean situation....
Old Oct 19, 2010 | 01:46 PM
cman1's Avatar
is there a way to check my injector for power before i remove them for cleaning,and do i need a gasket kit for this?
Old Oct 19, 2010 | 02:22 PM
A7QG59F2's Avatar
First make sure the wires to the injectors are plugged in tight, then with the engine running use a long screwdriver and put the tip on the each injector one at a time with the handle to your ear(watch your hair and clothing!!!!!) You should be able to hear them clicking as they open and close.
You could also try checking the resistance on all of the injectors. If the number 2 injector is way off from the other ones then it is a very likely culprit. I think they should measure between 13-14.5 ohms. If all the injectors pass this test you could use a noid light to make sure the injector is actually getting a pulse signal. There may be a short in the wiring somwhere. You should be able to rent a noid light kit at an auto part store.
Old Oct 19, 2010 | 03:57 PM
BajaRunner's Avatar
I think I remember reading about how early EFI's had some issues with the wiring to the injectors. I'd do a search for that and see if there's any info that would be useful.
Old Oct 20, 2010 | 11:18 AM
cman1's Avatar
checked the injectors for ticking,heard 1 and 3 good nothing on #2,very faint on #4.was going to ohm check but dont want to break the connector,sorry to sound stupid,but how do they come apart? i cant find a good pic.
Old Nov 10, 2010 | 02:22 PM
cman1's Avatar
dead dead dead....
well,i put new injectors in yesterday,fired right up...running smoother...but still a dead miss!!!!!!! anything stupid im missing?
Old Nov 10, 2010 | 02:29 PM
Shifty762's Avatar
Have you rulled out your ignition 100%? Ohm out your high tension leads to the plugs
Old Nov 23, 2010 | 10:18 PM
cman1's Avatar
yep,went as far as putting a plug on the end and it has great white spark,im not looking forward to chasing the wire harness...i think its my last option...
Old Nov 27, 2010 | 10:42 AM
cman1's Avatar
alright,im ready to set this f%$@#! on fire.changed the injectors,not only is #2 not ticking,now #3 is leaking fuel.im pretty sure that i can ohm check my injector wires with them all disconnected,but have never done this before, im assuming that i wrecked an o-ring during the process.please give me some direction/opinion so i dont have to do this again....please.:mad 2:
Old Nov 27, 2010 | 02:41 PM
BajaRunner's Avatar
You can get new o-rings at NAPA, so don't worry about that.
Make sure the ground wire for the injectors is clean, and not cut or damaged. It connects to the passenger side of the intake plenum, attached to a mounting nut that joins the intake plenum to the lower intake. its clearly visible without removing anything.
I've read some issues about the wiring connectors, where the wires run into the harnesses, at the injectors becoming loose. Try searching for "injector wiring 22re" on google or something.
Just curious, have you checked compression on cylinders?
Old Dec 4, 2010 | 10:54 AM
cman1's Avatar
22re dead miss
allright, i tore it apart again and replaced the o-rings,removed the fuel pump fuse and turned on the ignition,useing a 12v tester i checked the injector connector for power,it has power,put everything back together,started it up,still missing.found a place and rented a noid light kit,no signal!!! im kind of stumped now as of what to look for,so what i know now is that if i had a bad ground,i would have no power on all cylinders,correct? so is my next step to take it apart,AGAIN,and follow the harness back to look for a break in the wire? which wire would be the one that signals the injector? my f#@^&ng head hurts.....
Old Dec 4, 2010 | 04:24 PM
sam333's Avatar
Buck up , your doing a good job at working out the problem.
Old Dec 4, 2010 | 04:42 PM
bicklebok's Avatar
Hang in there man! You will get it figured out!
Old Dec 5, 2010 | 07:41 AM
cman1's Avatar
thanks guys,new day ... not as frustrated today...i was hoping that yota-clause came an cured my truck last night...... nope.
Old Dec 6, 2010 | 08:23 AM
cman1's Avatar
i tore into the wiring harness last night and found the crimp on the ground crumbled in my fingers...so i cut out the bad section on both ends, soldered the two ground wires from the acu to the four injector ground wires.ready for this,now im down two 2 cylinders!!!!!!wtf. checked the other leads and the blue injector leads were also corroded.repaired that one,no change.i havent gone as far as pulling that damn plenum off for the third time.now,all 4 grounds from the injector run together and are spliced into the two wires in the harness, am i correct?? and the injector firing wires (two yellow & two blue) also tie into the harness (one yellow & one blue)can anyone verify what im saying is correct? thanx...again!!
ive gone back and soldered everything together and i think im down to one cylnder firing!!!just so you know,i do have a haynes manual but am not an electrician. im seriously pissed.
Old Aug 27, 2011 | 08:10 PM
defrag4's Avatar
ever get it figured out?
Sleaker
Aug 26, 2020 06:03 AM
Colington
Mar 8, 2020 09:51 AM
MMA_Alex
25
Apr 18, 2017 05:07 AM
Sep 4, 2015 09:27 AM
Poncho0206
Jul 10, 2015 06:21 PM
