95 3vz-e running rich
Old Oct 19, 2010 | 10:53 AM
norcalyoda's Avatar
i have a 95 truck with a 3vz-e with a check engine light code 26 (running rich) put in new plugs and wires and a new fuel and air filter. i also pulled out the 02 sensors and they looked ok. i couldn't find any leaks in the air or fuel system. it failed smog and the smog tech said that cylinder 3 isint firing but i took a look at it and it has compression and a spark so i think that he may have just been wrong. does anyone have an idea of what it could be or where i should look next.
Old Oct 19, 2010 | 11:26 AM
TNRabbit's Avatar
If 3 isn't firing it could be the injector. Also, looking at an O2 sensor will tell you NOTHING~
Old Oct 20, 2010 | 08:10 AM
norcalyoda's Avatar
is there a way to test if the 02 sensor is working?
Old Oct 20, 2010 | 08:25 AM
camo31_10.50's Avatar
plug a computer up to it, that'd tell you.
or you could just run a search on here, theres a couple ways to test em.
see if it's getting power, check resistance?
Old Oct 20, 2010 | 11:16 AM
TNRabbit's Avatar
If you have over 100,000 miles on a O2 sensor, it needs replacing.
Old Oct 29, 2010 | 07:39 AM
norcalyoda's Avatar
got it fixed up it was a bad injector. its running like a champ now.
Old Oct 29, 2010 | 08:06 AM
TNRabbit's Avatar
Old Oct 29, 2010 | 08:38 AM
another score for TNRabbit!
Colington
Mar 8, 2020 09:51 AM
Doug4320
Mar 24, 2018 10:11 PM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
tj884Rdlx
Aug 28, 2015 12:04 PM
calderp
Jul 27, 2015 09:58 AM
