Front sway bar removal.
Old Oct 20, 2010 | 03:42 PM
UKrunner's Avatar
'91 4Runner SR5 V6 (swapped 3.4) Auto 4x4.
I see quite a few people have removed the front sway bar saying this gives a better ride. The brackets on mine are broken and the bolts have sheared off so its just hanging there. Should I fix the brackets or just remove the whole thing and forget about it? Can it be removed without taking the front wheels off?
Old Oct 20, 2010 | 04:02 PM
myyota's Avatar
Just remove it, you won`t miss it. You should be able to remove it with the wheels on, but it would be easier if you removed them.
Old Oct 20, 2010 | 04:38 PM
Randyman...'s Avatar
Cornering will suffer (body roll) - but unless you like to take fast corners like I do you won't miss it IMO. Since yours is already "dangling in the breeze" you are essentially getting a swaybar-less ride now
There's always the quick disconnect mod as well...
Old Oct 20, 2010 | 04:45 PM
92 TOY's Avatar
i removed mine (broke bolts when working on my driveshaft etc..) and have noticed zero change in the ride or handling.
have to be certain that it's not required for vehicle inspection though.
Old Oct 20, 2010 | 04:55 PM
You must not drive like I do I guess the urethane bushings also made mine more effective in high-speed cornering - but there was an absolute difference w/o it (I'm talking on-road). UK Runner won't notice any difference because his is essentially 100% useless in it's current state
Old Oct 20, 2010 | 05:51 PM
UKrunner's Avatar
Yeah there is a lot of body roll but I really dont drive it hard. If I wanted to reconnect it, what are my options? The bolts are sheared right at the surface. I dont see any easy way of ever getting them out.
Old Oct 20, 2010 | 06:08 PM
Swimmerboy2112's Avatar
I've heard very conflicting reports about this. Some people say it makes your ride garbage, some say it doesn't do anything. I wanna take mine off but the bolts will probably break if i do and i don't want to be stuck with a crappy ride if i do remove it.
Old Oct 20, 2010 | 06:09 PM
I'm far from a broken blt expert! But "1990yota-pickup" recommended this stuff in another thread (gas tank) to loosen any rust:
http://www.grainger.com/Grainger/wwg...N=0&sst=subset
Then maybe an eazy-out or similar?
I'm in a similar boat with my front A-Arm mounts - a buddy of mine crossthreaded one of them and I really don't think I'll be able to get it out w/o snapping it (I'm surprised he ws able to tighten it all the way down!). I have no clue how to get at it with the boxed frame and all
Old Oct 20, 2010 | 06:11 PM
RE Swimmerboy - You will have better "independence" of your front L/R if you remove it which is a no-bainer for crawling and rough un-even terrain IMO. For highway driving and on-road cornering - the sway bar makes a marked improvement in body roll (aka: Faster Corners )
You can make cheap quick-disconnects if you want - or simply try it with and without in all of your usual driving conditions and see which you prefer. I'm mainly a daily driver - so I prefer on-road cornering hands down...
Old Oct 20, 2010 | 06:17 PM
Thanks for the input Randyman, i guess tomorrow if its not bitter cold out, i can go out and do some wrenchin. My 4Runner is my DD until i get another DD and can use this primarily for wheelin.
Old Oct 20, 2010 | 06:23 PM
4Crawler's Avatar
For a quick test, just disconnect one or both of the end links at the control arms and see how it works for you. If it handles OK, then remove the brackets from the frame, if not, put the end links back on.
PS - If your bushings are worn consider replacing them as the swaybar's effect is greatly lessened with worn bushings...
PPS - If you disconnect BOTH end links you'll need to tie the swaybar up with wire so it doesn't flap around
Old Oct 20, 2010 | 06:44 PM
That's a good idea.
Well my bushings are 24.5 years old so i'm sure they're not the greatest...
Old Oct 20, 2010 | 06:51 PM
UKrunner's Avatar
Well for now I'm going to pull it out until I can get the bolts out. I do very little off roading with it and what I do is mild enough that a sway bar fitted wont effect the trip. I'd like a little tighter handling. Who makes poly bushings for front and rear suspension?
Old Oct 20, 2010 | 06:56 PM
I haven't checked in close to 10 years, but I got my Urethane suspension bushings from NWOR. Coming from the worn stock rubber ones was night and day. The ride will be a bit bumpier since the rubber isn't there to cushion the ride as much, but the tightness and handling/steering respose is VERY nice IMNSHO. Just make sure you or your buddy doesn't crossthrerad the A-Arm bolts when you re-install everything like my buddy did to my truck :mad: (10 years later and I'm still pissed!)
I'd get an alignment afterwards, too
Old Oct 20, 2010 | 07:02 PM
Alignment, there's something i desperately need but i've been pushing it off until after my lift.
Old Oct 20, 2010 | 07:04 PM
Tires ain't cheap (at least BFG's aren't )
Old Oct 20, 2010 | 07:05 PM
UKrunner's Avatar
I need one of those too. Both front tires are wearing more on the inside. Runs down the road perfectly straight and smooth though.
Old Oct 20, 2010 | 07:07 PM
Mine is just the opposite, the outsides wear more than the insides.
Old Oct 21, 2010 | 12:18 PM
4runner530's Avatar
if you take the sway bar off will it make your tires wear unevenly
