PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 [32] 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266
  1. Grinding sound after replacing leaf springs in 1st gen 4runner...
  2. FWIW, Those cheap front end kits on EBay
  3. Clutch master cylinder question
  4. Check engine light electrical issue
  5. Early to Late 22r Fuel Pump
  6. 90 Pickup 4x4 auto swapping to manual
  7. transmission fluid
  8. Replace Light Bulb inside A/C Switch - Help?
  9. Pressing Clutch Lowers Fuel Pressure
  10. Need advice
  11. FJ Cruiser Wheels for 2nd/3rd gen pickups, 4Runners: Thoughts, Experiences?
  12. Brown sludge on coolant lines?
  13. rear wheel bearing case stud orientation
  14. Holy crap!
  15. Replacing Carpet - Have to remove Rear Seat Heater?
  16. Accidently poured 5 gal of water in the fuel tank
  17. Vacuum Hose Routing Diagram Sticker
  18. A healthy Spark plug?
  19. 22re won't idle
  20. Quadrajet? Or no quadrajet?
  21. Help! I need the Torque for the Torsion Bar Torque bar
  22. Rear bumper options?
  23. What is this and does it need to be replaced?
  24. Wheels
  25. Rear Axle Bearing And Retainer: 12 ton Press
  26. Has anyone bought/used aftermarket LCA's?
  27. SR5 Replacement Fabric - Any Options?
  28. 87 4Runner SR5 - Door Locks Stopped Working - Clicking Sound?
  29. 87 4Runner SR5 Turbo - Headlights go on, Dash/Interior Lights go off
  30. Unknown part leaking
  31. 22re Exhaust question
  32. 4runner fuel injectors not working
  33. drill and taping for stock turbo non stock block
  34. door replacement 95 4Runner
  35. 90 4runner seized distributor
  36. Help identifying a leak
  37. 22re missfire when warm, hard to start
  38. 93 Toyota Pickup 4WD Steering Stops (Not Covers)
  39. Electrical Schematic for Horn?
  40. Re-doing the rear axle bearings and seal
  41. 87-88 2wd grille swap
  42. 87' Runner window problem
  43. Transfer Case Question
  44. 95 parts in a 84 block, Will it work?
  45. '95 T100 3RZ won't start
  46. Excessive grey smoke after ENGINE SWAP
  47. New engine valve lash
  48. '95 4runner EFI relay draining battery
  49. Transmission Mount Help!
  50. Removing/deleting running boards from 1990??
  51. Help with coolant leak toyota pickup
  52. 86 toyota pickup 4wd fix up
  53. 92 4runner with a340h transmission
  54. Headlight: Troubleshooting
  55. Blocked EGR, runs sluggish
  56. Sloppy Steering
  57. Horn not working - steering wheel not making connection to the steering column
  58. torsion bar adjuster bolts & Nuts
  59. What spare parts do you keep in your truck?
  60. Toyota Truck 1986 original stereo
  61. 1st gen 4Runner lift
  62. 87 Turbo pickup Accelerator cable
  63. Brake light on?
  64. 3vze idle trouble. Go figure.
  65. 86 P/U engine overhaul.
  66. replacement part of OEM N°04562-89101
  67. '87 4Runner SR5 22RET WTB Fuel Sending Unit?
  68. Vibration issue
  69. coil spring isolators
  70. truck problems 22rte 87
  71. Brake lines!!! Holy whoa!
  72. 93 SR5..... Fresh paint !
  73. 3rd gen pickup suspension rebuild. 2" lift with ride quality priority
  74. Common problem/weak point on the speedometer gauge?
  75. Speedometer Not working Properly
  76. 1987 22RE Hard Start in the morning NEED HELP!!!
  77. Automatic Transmission drain vs flush
  78. Fast idle time when cold?
  79. 1990 22re ignition coil question
  80. Will a G52B manual trans from a 87 pickup fit in my 94 pickup
  81. 1990 pickup won't start. Blown 80 amp fuse
  82. 94 Toyota pickup wont start... Flashing red light on Dash and beeping sound
  83. Gap Guards or Fender Apron Seals
  84. 95 4Runner Fan Switch Replacement...With Clock
  85. Why is pumping gas a chore?
  86. Can you make an effective skid plate with a 90 AMP flux welder?
  87. ticking top end time bomb on a freshly rebuilt 22RE
  88. Grinding Noise
  89. Help me identify a part number (rubber stop in front suspension)
  90. Does my idler arm need to be rebuilt?
  91. Is it possible to overgrease?
  92. 1990 22re fuel filter question
  93. '86 22RE Stalling when engine warms up
  94. single click noise inside cab when trying to start.
  95. 22Re surges after getting warm
  96. Brake caliper's
  97. Stuck in 4 wd
  98. Looking at a truck what is it worth ?
  99. 1986 headers
  100. 1994 4runner Power problem
  101. 3rd brake light
  102. Body panel swap- 91 4 Runner to 94 4x4 pickup?
  103. fuel injector lube
  104. Recommend me a good steering/suspension shop in Fresno
  105. Kayline soft top measurements
  106. Cylinder Head Studs for the 3VZE V6 Engine?
  107. Camper Top
  108. steering knuckle and spindle swap
  109. 95 4 runner 3.0 no start inj pulse and spark ok
  110. Finished 22re rebuild, truck starts wont idle
  111. Check engine light won't flash with TE1 and E1 jumpered
  112. torque specs for front shocks
  113. 1990 toyota pick-up, shifting?
  114. Need clips for outer weatherstrip - LH door glass
  115. Budget Spare Tire Carrier Solution
  116. 1994 3vze Smog fail. High HC at idle
  117. ADD 3rd member question
  118. Timing with and without vacuum attached... Vacuum leak?
  119. Lack of oil, passenger side cam 3vze
  120. Where does this get wired up to?
  121. Mcm legacy camper shell rear window glass search of Mcm legacy camper
  122. 88 pickup won't start
  123. 1988 pickup starts in morning but won't stay running
  124. Fuel line from fuel pump in tank?
  125. egr delete on 91 3vz-e
  126. How much drag on front wheels?
  127. Loose auto shifter
  128. What is this light?
  129. Speedo Cable
  130. Help! Installed rebuilt engine and clutch fork stuck/broken slave cylinder
  131. engine mounts vibration
  132. Hauling my dirtbike
  133. Huge Coolant Leak
  134. No EFI after heat sink with 3.0
  135. Stock Ride Height?
  136. ac compressor relay...
  137. 1993 pickup 3vze miss intermittent
  138. Fuel pump or electrical issue?
  139. Toyota pu 3.0 running slugish
  140. 22re pickup vs 3rd gen 3.4 4runner
  141. Throttle Position Sensor
  142. 1993 Toyota T100 no start
  143. Rear Axle interchange for 95 4Runner SR5
  144. 3VZE Upgrade
  145. Toyota Part Numbers
  146. another code 52 knock sensor issue possibly from fluid leak out of throttle body?
  147. Derale 15405 oil cooler install on a 3vze
  148. Wanted to introduce myself
  149. Mechanical speedo sensor w56
  150. 22RE loose headbolt
  151. Gas pedal stops halfway
  152. Truck repair
  153. Vacuum Hose Information decal
  154. New Toyota
  155. 1990 22re fuel return line hose
  156. Gear Shift Light Bulb 94 4runner
  157. RUF SAS on a 86 4Runner Help!
  158. RUF SAS on a 86 4Runner Help!
  159. fuel return line hose from fuel pressure regulator
  160. Auto tranny late shift
  161. Worn valve adjustment Screw?
  162. 1994 Toyota 4x4 Hilux Pickup Standard Cab
  163. 91 22RE Shudder
  164. 1992 4runner - I keep burning EFI relays
  165. 22re alternator in a 22r?
  166. Interior
  167. 94 4runner. idles but dies and restarts during drive
  168. Front and rear O2 sensor question ?
  169. '94 4x4 IFS: Separating lower ball joint from steering knuckle
  170. Auto zone clutch master cylinder???
  171. 86 carburetor problem
  172. Auto to manual trans swap info needed
  173. Concerning rattle/grinding from front near suspension/wheel, intermittent
  174. 1986 4Runner Frame measurements?
  175. Help with 1995 22RE fuel injector wires....
  176. Any Tips for Rebuilding Leaf Springs?
  177. Linked fuel line
  178. new timing chain and guides time/opinions
  179. Crank Pulley Wear Line
  180. NEED HELP ASAP: Rear lift for 91 SAS
  181. What Bolt and Bushing for the Leaf Spring?
  182. walmart supertech motor oil?
  183. load noise after replacing timing chain
  184. 1990 4runner Intermittent starting problems
  185. Need help on flame thrower injectors
  186. 1990 4wd Reg Cab Short Bed: Grandpa's lil' Putt Putt
  187. Engine swap question.
  188. grease for '97 4WD Tacoma calipers
  189. IFS 7.5 V6 vs 4Cyl
  190. 93 truck tragedy
  191. Why Does My 1993 SR5 Speedometer Work Intermittently?
  192. Clutch must touch floor to engage reverse
  193. Super Weird -Combined- Transfer Case/Transmission Output Behavior
  194. Whine/Whistle while up to speed
  195. Rewiring my radio help (PO hack)
  196. Thought I would share an experience
  197. Helping my buddy with his truck
  198. jhuggz 87 4x4 pickup
  199. 90 4runner trans removal help
  200. how do i block off all the water lines unnecessary to cool the engine?
  201. Power Steering Pump Rebuild?
  202. anyway to tune a 93 Toyota to run better on10% ethanol
  203. Springs
  204. 22r code help.
  205. Suspension Advice
  206. Exhaust popping/backfiring after desmog during enginebraking
  207. Is this a TPS issue?
  208. Fuel Pump or Fuel Pressure Regulator?
  209. UCA against frame?
  210. 89 pickup 3.0 wont start
  211. Engine build on a '89 Pickup
  212. 1990 4runner 4wheel drive not engaging
  213. 1st gen 4runner Weatherstrip cab/top
  214. Ifs drag link drop
  215. '90 Rebuilt 22RE EGR Code 71 Rough Idle/Dieing
  216. Increasing turning radius on 89 extended cab??
  217. SAS with a drive flange? No hubs.
  218. keep blowing dash fuse
  219. 1991 Toyota still having idling issues, I've tried a number of things
  220. power steering gear box interchange
  221. 3vze timing retarded
  222. 22r Carburetor Tuning
  223. Battery Tray part number for 1986 pickup 4wd
  224. 87 4Runner sputtering at 2400rpm and beyond
  225. Slave cylinder line bracket.
  226. Ignition switch swap & High Altitude Compensator replacement
  227. Replace head gasket now not getting spark from coil
  228. '93 Xtra Cab Resto Project in Wisconsin
  229. Sweet V6 '88 4runner for someone
  230. Using ATF as P/S fluid?
  231. Need help finding an a/c line
  232. Coolant in Intake Manifold
  233. More - My 87 Toyota 4X4 or Fun and mysteries of restoring a Toyota 4X4 that is a "gem
  234. How to replace sliding window seal on 88 4Runner removable top?
  235. 4Runner RC model
  236. Help finding correct parking brake cable 90 3.0 sr5 4x4
  237. Gas tank pressure
  238. 22re Upper Radiator Hose Diameter?
  239. 95 toyota pickup
  240. I have a 1992 toyota pickup extended cab, she has a really hard time starting up
  241. 3.0 rebuild- runs- won't rev up- dies
  242. shock length.
  243. high fuel consumption
  244. 1986 22re bubbles coming from radiator.
  245. Ac pressure spiking, engine getting hot at idle
  246. Vapor lock
  247. Anti Lock Light
  248. Neutral/clutch safety switch temporary bypass?
  249. Top end knock
  250. 88' 4 runner issue
