87 Turbo pickup Accelerator cable
Old Oct 10, 2017 | 11:42 AM
darmentle's Avatar
I have a 1987 4x4 Turbo pickup and its in dire need of new throttle cable. trying to avoid going to the dealer price, so does anyone know of any other years that will interchange with? thank you.
Old Oct 10, 2017 | 12:12 PM
wyoming9's Avatar
Red face
I doubt you will even find a new one
Any of the 22re pick ups and 4 runners should work
I need to look to see if the throttle body is mounted in a different spot
The only thing really different is the air intake piping
Old Oct 10, 2017 | 01:34 PM
dropzone's Avatar
Fossilized
my throttle cable broke on 4th of july. my 5 minute temp fix using zip ties is still going strong...
Old Oct 11, 2017 | 07:47 AM
Co_94_PU's Avatar
I don't recall there being anything special about the turbo engines cable.
What issues are you having with it exactly?
Old Nov 2, 2017 | 06:44 AM
darmentle's Avatar
i got a throttle cable for a 22re from rock auto , and the 22re version the way it mounts to the fire wall is different it uses a soft rubber , and the turbo one use hard plastic that mounts to firewall, the other thing that i noticed is the end of the cable that mounts to pedal the ball would not fit into the hole?
Old Nov 2, 2017 | 06:58 AM
darmentle's Avatar
Truck has an issue with throttle not returning fast enough likes to hang up there especially on cold mornings until the truck warms up, i have disconnected dash pod removed cable and lubed it up. truck has 360000 on it, looks like the factory cable so i was going to try that next.
Old Nov 2, 2017 | 07:39 AM
Travis11870's Avatar
22re turbo
I planing on doing a turbo build on a stock 22re what do i need to do before I install a turbo any ideas would be helpful
Thanks
Old Nov 2, 2017 | 08:25 AM
darmentle's Avatar
Thanks
my truck is turbo from the factory not aftermarket. you could try a cheap universal one off eBay and fab something up. i would rather have the hilux turbo diesel.
