need help ignition coil options ????
Old Oct 25, 2017 | 11:08 AM
dillonholden's Avatar
noticed some oil leaking from my ignition coil . . . been searching the internet for a good OEM replacement but no such luck yet! any help would be great!! ( 88 pick up 3.0 v6 4x4 )
Old Oct 25, 2017 | 11:27 AM
scope103's Avatar
Do you mean you want an OEM coil to replace the one you have? Since the Original Equipment Manufacturer (so far as you know) of that coil is Toyota, it's traditional to just drive around until you see a big business with lots of new cars and a "Toyota" sign. (called a Dealer). Or try: https://parts.lakelandtoyota.com/p/T...091902113.html (also a Dealer)
Or, do you mean you want a good coil to replace the OEM coil? RockAuto has lots of them: http://www.rockauto.com/en/catalog/t...tion+coil,7060
Just where have you been "searching the internet", by the way?
Old Oct 25, 2017 | 01:16 PM
Mclaws89's Avatar
I have found lots of good stuff like that at salvage yards. OEM and takes all of two 10mm bolts to pull it out. You can always keep the receipt in case the coil is bad or that it wasn't your problem to begin with. I have never heard of a coil leaking oil...
Old Oct 26, 2017 | 07:20 PM
QUOTE=scope103;52380436]Do you mean you want an OEM coil to replace the one you have? Since the Original Equipment Manufacturer (so far as you know) of that coil is Toyota, it's traditional to just drive around until you see a big business with lots of new cars and a "Toyota" sign. (called a Dealer). Or try: https://parts.lakelandtoyota.com/p/T...091902113.html (also a Dealer)
Just where have you been "searching the internet", by the way?[/QUOTE]
Just read this correctly! thanks ordered the coil
Yes I would like an Oem replacement for the aftermarket coil that was installed by the pervious owner! lol I've tried rock auto but it doesn't seem like they have anything factory. google seems to think they've been discontinued !?
Old Oct 26, 2017 | 07:21 PM
yes they even said oil filled when you buy a replacement
Old Oct 26, 2017 | 07:49 PM
shafner30's Avatar
I was trying to get a coil1990 22re the other day The guy at Toyota parts said there is no coil‘s in the United States for sale it’s on permanent back order
Old Oct 26, 2017 | 07:53 PM
scope103's Avatar
What? You want a Toyota OEM coil. You haven't tried a Toyota dealer. You don't look at the dealer website (showing the coil you asked for) that I provided. You looked at RockAuto (which doesn't sell Toyota-branded OEM parts), And you say "google seems to think"??
Old Oct 26, 2017 | 10:04 PM
Wonder what our next best solution is ?
Old Oct 27, 2017 | 01:28 AM
wyoming9's Avatar
Red face
Go to Napa tell the Counter People you need a Coil for your 1988 3.0 part # ECHIC150
Since the coil is leaking that is a good place to start
Then no doubt a bunch of these coils laying around from the 3.4 swaps
Lots in yards as well Check out Carparts.com
Old Oct 27, 2017 | 10:12 AM
thanks ! Just curious of the brand ?
Old Oct 27, 2017 | 12:47 PM
Mclaws89's Avatar
Interesting. I guess maybe I know nothing about the coils. I will need to break one open now
Old Oct 27, 2017 | 12:49 PM
Mclaws89's Avatar
I have one out of my 89 3vze
Old Oct 27, 2017 | 07:48 PM
wow sorry such a newb on here! was replying from my phone and i seemed to have missed the link where you posted the coil haha thank you so much !
Old Oct 28, 2017 | 06:37 AM
Terrys87's Avatar
I have not checked the links for OEM, but a Haynes Manual and a Multimeter will tell you if you have a good one from your local salvage yard. Just need to measure the Primary and Secondary resistance on the coil. If either one of the test fails, it is a bad coil. All of my OEM coils are salvage and work great.
