engine mounts vibration
Old Sep 24, 2017 | 07:47 PM
yogi.ali1's Avatar
hello,
I have a 92 toyota pick up truck, 22re motor. i just did an engine rebuild. i followed the toyota service manual very thoroughly. truck starts right up , ran the motor for about an hour and checked oil is clean and no leaks of any oil or coolant appeared anywhere. the only concern i have is when i go into gear reverse or drive , the whole truck shakes and vibrates. in neutral or idle its fine. any suggestions please help me out. i appreciate it.
Old Sep 24, 2017 | 09:11 PM
scope103's Avatar
I assume the shaking is at idle. I assume you have an automatic transmission. What is the idle speed set to? (To high can lead to vibration.)
Old Sep 25, 2017 | 05:47 AM
yogi.ali1's Avatar
Engine vibration
Yes automatic. im not too short, that’s one thing I couldn’t figure out. How can I check that?
Old Sep 25, 2017 | 07:16 AM
scope103's Avatar
You couldn't figure out the idle speed spec? (it's on the under-hood sticker; for an auto it should be 850rpm)
Or you couldn't figure out what a tachometer is?
https://www.harborfreight.com/lcd-au...kit-95670.html
https://www.aliexpress.com/item/1set...785397930.html
Old Sep 25, 2017 | 12:07 PM
yogi.ali1's Avatar
can I use a timing light instead?
Old Sep 25, 2017 | 01:22 PM
scope103's Avatar
Originally Posted by yogi.ali1
... 22re motor. i just did an engine rebuild. i followed the toyota service manual very thoroughly. ....
Hmmm. You did an engine rebuild, but you don't know how to measure engine rpm?
I guess I should ask: does your truck have a tachometer? (a gauge on the panel next to the speedometer, that shows the speed of the engine).
A "regular" timing light won't tell you anything about rpm. But there are some fancy ones (always with a digital display of some sort)
Amazon Amazon
that "also" will tell you engine rpm. If you have one of those, it should work fine.
Of course, you have to know how to use it ....
Old Sep 25, 2017 | 04:16 PM
yogi.ali1's Avatar
A "regular" timing light won't tell you anything about rpm. But there are some fancy ones (always with a digital display of some sort) https://www.amazon.com/INNOVA-5568-P...8J8/ref=sr_1_1 that "also" will tell you engine rpm. If you have one of those, it should work fine.
this was my first engine rebuild, am very thankful it went well. My truck does not have a tachometer. I can go to harbor freight and grab one. Thanks again for your help!
dntsdad
3.4 Swaps
59
Oct 15, 2021 04:17 AM
egesledder
All Other Toyota Swaps
120
Feb 22, 2017 06:14 AM
Rock Slide
37
Apr 3, 2007 08:26 AM
DavidO06
9
Aug 15, 2002 09:18 PM
